- Jan 15, 2011
Hello All,
Today i updated my B550 Gaming Edge Wifi and my Brother his B550i Gaming board to the new 1.2.0.7 Agesa bios. We are both running a 5800X3D.
I notice my 3DMark CPU Scores are quite a bit lower with the new bios. The CPU does not seem to boost as high as before. Now 4450MHz istead of 4550.|
All core clocks also seem lower:
www.3dmark.com
Here you can see the compare between the 1.2.07 and 1.2.0.6.c Bios. The 1.2.07 is even running a higher BCLK to try and compensate (the old bios would not boot that high tho).
But as you can see the performance is quite a bit lower due to the lower boost clocks so im switching back again. The BCLK OC version is just as fast as 1.2.0.6c stock.
I would also like to See a option to undervolt the CPU. And be able to set lower Power and Temperature targets in the BIOS.
I know AMD locked overclocking because higher voltages and temperatures can damage the Cache.
But why not add undervolting like ASUS did.
i would also like to lower the PPT from 142 to 125-130 watt. And lower the max temp from 90c to like 80-85.
PBO -CO should also be available. I again understand that +CO is dangerous but lower voltages are better for the lifespan same goes for lower power targets and temperatures. So why not add those?
Result
