Initial Results are not that great here:
Its again much slower on stock BCLK.
And this time 103.687 BCLK was not even stable anymore. With the E7C91AMS.190 1.2.0.6C bios i could run up to 103.9x BCLK and still run 3DMark stable.
With this 1B1 bios only 4,2 and 1 thread would be stable 16 and 8 are crashing straight away.
The Score of the 1T was also way lower 908 vs 928-933 with the 1.2.0.6C bios.
So even if the UV will help me get performance up a bit i doubt it will be faster than the 1.2.0.6C bios. But i will do some more testing.
Edit:
This is with Kombo Strike mode 2. Performance is now slightly up compared to stock 1.2.0.6C. But Mode 3 was not even stable it crashed. So i dont think i will have any BCLK OC headroom left when running mode 2. I will now first test some UV to see what that does for the performance.
Edit2:
-voltage offset lowers boost clocks. CB R20 and 3DMark scores are lower if you apply a lower voltage. I noticed the same thing happening with the old bios when i was messing with LLC to get a lower load voltage. You need to use Kombo Strike to get the performance back up. But my CPU is already 3DMark unstable with -0.0250v and KS Mode 2. So i wont be able to beat the performance of the 1.2.0.6C bios its way better performance and stability wise.
