B550 gaming edge wifi wont post/ enter bios /or anything else
wittbri126a02ac
I've been out of the pc building for the last 5-10 years. My sons are getting into gaming so I figured I'd dust of my skills and build a new pc for them. I can't get the mobo to post, no bios, nada. No bios beeps but I think that might be old school. I've reseated the cpu, memory, removed everything not necessary. Tired 2 psu. I've bench tested so it's probably not a grounding issue. Fans, lights, disk drive, all turn on. Any ideas?
Active member
Can you list all the components please?
Have you tried a Clear CMOS?
wittbri126a02ac
3600x, crucial ddr4 3200 16x2.
I haven't pulled the cmos battery if that's what you mean, is there another process?
Active member
Yes, check the manual, it's explained under Clear CMOS. You just have to short two pins, with a screwdriver or a jumper cap. You never have to take the battery out on mainboards nowadays.
Alan J T
Retired
What CPU and What GPU are you using. A lot of AMD boards and CPU do not have on board video. But need a separate GPU.
