B550 Gaming plus m2 screw
wouter.oa155b02d7
Hey,
I don't know if this is the right section but I have a b550 gaming plus and want to install my secondary m2 ssd, but it seems i'm missing the screw, I got the standoff.
What screw would I need and where could I get it ? I checked the extra screws but sadly it seems to be just missing :/.
Thanks,
darkhawk
While I can't say with certainty that ANY of them will work.....
That's probably your best bet.
Are you sure there wasn't an extra screw included within the box for it in a plastic bag? I seem to remember that usually they did that for the secondary slot.....
wouter.oa155b02d7
Honestly idk, I couldnt find it seen people online having the same issue, maybe we all lost it, maybe its just just a few boards they forgot to add an extra, who knows. I don't mind spending $5-10 for the screw but wouldn't want to buy the wrong one xD
darkhawk
Yeah, I hear you there. I'm not really sure what to say at this point.
I know you're in the EU, is there maybe a shop nearby that might have some you can buy from them?
Other than that, all I can really say is to buy one and give it a try :/
micsim2007
CORPORAL
The screw is in a very tiny and thin plastic bag, it can easily slip under the folded sidewall of the motherboard box so it may well be in there somewhere still (or in the supplied literature).
commo8158602e0
Hey,
Thanks,
There was a little tiny bag in my board with 2 tiny m.2 screws for the NVMe SSD's. I easily overlooked them the first time, found them in the box 3 hrs later between papers.
