B550 MAG Tomahawk Bios Flash Issue
I'm not particularly new to PC building. I've been getting MSI products for ~10 years now. I have never had an issue as frustrating as this.
Problem: The BIOS will not flash.
History: I used the flash tool within the BIOS itself to update using the latest non-beta bios found here. The reason I attempted an update was I has accidentally deleted the first array when setting up RAID. Last week I got the same board and tried to flash it as well (different reason), and I had the SAME problem. I sent it back thinking it was a manufacturing error.
The BIOS update within the GUI runs and completes just fine. Following the update, the computer refuses to boot. The DEBUG LED lights CPU. The CPU is a working and functional AMD Ryzen 7 3700x.
So, the real headache begins. I have tried using the M-Flash tool what seems like a dozen times. Here are the things I have tried:
  • 4, 8, 16, 32, and 64 GB flashdrives
    • Have been formatted in MBR and GPT in combination with Fat, Fat32, and NTFS
  • CMOS reset both by jumpers and removing the battery
  • Formatting on a different computer
    • Tried with CMD, RUFUS, and Window's utility
  • ALL things except CPU/MB powersupply cables have been removed
  • Renamed the file "MSI.ROM"
    • the file I rename and copy is (following extraction) the .A10 (I think) file -- nothing else
  • The drives are always inserted when the system is powered off, the USB is in the top leftmost USB port, and the flash button is then pressed
What happens when I attempt to M-Flash? The M-Flash LED will blink endlessly-- even left it overnight. I usually wait 10-15 minutes before calling it a fail. On some trials, following pressing the button, the computer will start while flashing. Other times it remains off.
I find it exceedingly unlikely that I have gotten two boards which refuse to flash. However, this is where I'm at. I'm hoping I am making a major noob mistake. I am currently trying different BIOS versions to no avail.
Any help would be majorly appreciated.
-Byron
Administrator
Can you tell the full BIOS ID of the current installed BIOS version?
Administrator
Have you tried using 1 memory stick only?
f.boisselie156b02db
Hello I have the same problem. Following the update of the 7C91vA0 bios to 7C91vA4 the PC does not start anymore and I have the CPU LED on I have a ryzen 3700X on B550 TOMAHAWK motherboard original bios version 7C91vA0. I tried a reset by removing the battery, using the jumper nothing worked. I tried to reinstall the original bios with a USB 1 key, then USB2 then USB3 with the flash bios button. it blinks for hours or all night. I removed everything from the motherboard, RAM, CPU, SSD remains connected only the ATX power supply. And nothing. If you have found a solution, I am interested.
