B550 tomahawk no boot,no flash not turned on
Greetings,
I bought b550 mag tomahawk
Ryzen 5 3600
16gb ddr4 3200
480gb ssd
Rx 5700xt
My mobo not even turned on even i put all cable correctly
This is my first build with amd
I even clear the cmos
Nothing happen
Plus i bought a new psu 650 bronze
Still cant boot
i push the flash light button there's a red led
what is the caused it cant boot/post?
i tried everything
can someone help?
I even
Administrator
What debug led shows when you can't boot?
Have you tried to boot with 1 memory stick only?
Can you list detailed system specs too?
Hi sir
The led debug also doesnt came out, i really frustrated. I also tried with 1 stick even bought new psu. Still same here.
Ryzen 5 3600
Msi b550 max tomahawk
Msi rx 5700xt mech
8x2 ddr4 3200
650 bronze
480gb ssd
2tb hdd
I alr call technician they said mobo faulty for sure but the seller doesn't take responsible for the faulty mobo. They just ignored me.
leth5591
First try installing 1 memory stick in the A2 memory slot of the motherboard,assuming you have 2 sticks. You will have to push down very hard until there's a click sound. When you boot, did you hear a loud POST beep? I did not hear anything, so initially I thought my MSI (B450M PRO-VDH MAX) board was faulty. Once I inserted 2 sticks in the A2 and B2 slots correctly, I was able to boot to BIOS screen. Inside this so-called ClickBIOS screen, the Boot menu item shows that POST is disabled by default. You will have to enable POST in order to be able to hear the beep. By the way, you also need to have the tiny PC speaker connected to the motherboard in order to hear the POST beep.
I even done try your method even the technician try yours also even we try to jump start nothing post. My ram both dua channel. I bought new mobo b450, my ram ,cpu works perfectly. I sent back the mobo but the seller trying to blaming me for the faulty. I've been built so many pc. This was the first time i got faulty mobo and i frustrated.
paluszkowo1160402ec
How the story ended? I heard that there is sometimes a compatibility problem with AMD graphics cards or RAM.
I bought same MoBo, CPU but nVidia 2060Super and 2xDDR Royal Silver 3600CL16.
All works fine but I can't make update BIOS via Dragon Center. I took out the battery and it was only this that helped get the old BIOS back.
Dont ever use dragon Centre because it is pain in the ass. Terrible apps. I just returned my mobo because they said my board DOA. I get new one straight away
Noice, I returned mine yesterday in topAchat (french retailer), waiting for their feedback about it, the Customer service guy had pain to believe me when I explain him what the crap with this board. Looks like it's exceptionnal ?
If they argue you just say it whatever you've done. I rather return it directly to supplier or main centre. Much easier plus fast response. I hope you get your board soon and happy gaming
