I appreciate the help of friends.
ErP is a resource that I consider very useful, including energy saving, where you need the equipment to be almost turned off when idle, with your devices on, but consuming very little whats. I used the feature for that.
So, in my understanding, it doesn't make sense to disable something as useful and smart as that for my setup. But, if there is no way, then the "solution" is to disable. Do what?
I noticed that they released a new BIOS, but that seems to only resolve language issues. That's right? It's in Beta.
About what you asked me, do you want just the config file? I had already sent it to another person here in the group who tried to help me with this. No problem, I can forward again. I'll need to reboot here to save and export the profile.
About what you pointed out, if they are doing sequential reboots, this will not reproduce the same problem that I have. The problem occurs as follows:
1- The computer turned off, for a period longer than 30 minutes, hours or days, when turned on, it shows the boot, but not its sequence with the MSI logo screen and the words with the choices for the boot. Only black screen and LED lit on CPU;
2- To return to normal, I need to try one of these options: Press the Power button until it turns off (when this happens), or press the Reset button (when this happens), press Power and Reset together (when this happens) and, or choose by turning off the power switch (this solves it in all cases).
I'm not a fan of overclocking, I just do Boost which for me is very efficient and I use XMP. I set my memory tRC to 56T which is the default for it. I don't do anything fancy in my BIOS. And, it's always worked for me, but not in these last few AGESAs.
I'm still not going to update to this new Beta that came out, because from what I saw there is nothing more than the language. Or am I wrong?
