B550M mortar wifi motherboard boot issue
b2sbhatt46b50692
b2sbhatta
Hi ,
Purchased a new motherboard and peripherals
Ryzen 5 3600
MSI B550M MOrtar Wifi
GSkill Ripjaws V
However, I'm unable to boot as it says UEFI GOP issue and use graphic card which supports.
I'm trying with Nvidia GTX 660 Ti and is there any known issue?
I'm not sure which version of bios is being used for me to even update the same.
zerijelly
FIRST LIEUTENANT
Would the issue happen with both DP and HDMI output?
Due to BIOS default UEFI mode, once the GOP driver on the graphic card is outdated, it may cause no display.
Try set [BIOS UEFI/CSM Mode] to CSM Mode under BIOS\Settings\Advanced\Windows OS Configuration, this shall make the graphic card able to display.
