b560m mortar wifi argb problems
megadote154d02d7
Good afternoon.
Help solve the backlight problem.MB 560m mortar wifi
I assembled the computer, connected the argb backlight to the jrainbow1 output. Everything worked, installed msi center and this program suggested updating the BIOS. Well, I updated it and after that the backlight was reset to work. The mystic light function disappeared from MSI Centra and the backlight went out and did not turn on anymore.
Msi support to help solve the problem.
They dropped the led update tool. but it won't install. How can I solve this problem?
fatedust
Survey Corps
FIRST LIEUTENANT
Are you using MSI Center 1.0.31.0? Have you tried to go to MSI Center > Support > Live Update > Advanced > scan for any available LED FW update?
Don't tell me that the LED firmware is dead already..., make sure you told them correct motherboard model.
megadote154d02d7
yes, the latest version is installed and yes there is no update.
when I try to install an update that was sent to me by msi support, it gives the error "conection to device fail"
fatedust
Survey Corps
FIRST LIEUTENANT
As far as I understand, you can run LED update tool without MSI Center and Mystic Light installed, so I will tend to think this is more like a hardware problem.
