Model numbers of the M.2 and Photos ot the probem please
"Na sorry I am returning this [MOBO] way too many weird issues with it!"
And I am sadly not taking it apart from the CPU & RAM at this moment, I will first contact the shop about this.
But if you want full story, as I realize how badly made this MOBO is.
I leave some info on [MSI-B760] I will return to the shop...
M.2.Cards: None fit.
You can read this: & the M.2 cards are - [
https://www.pricerunner.se/sp/samsung-970-evo-plus-ssd-m.2.html] & [
https://www.pricerunner.se/pl/36-3201024678/Haarddiskar/Corsair-MP600-PRO-LPX-SSD-1TB-priser] & I did also try a [
https://www.pricerunner.se/pl/36-3202489633/Haarddiskar/Kingston-NV2-SNV2S-1000G-1TB-priser]
"And trust me, none fit, it´s like a gap a very weird gap, the same issue the ROG-MOBO have people complain about M.2-faulty gap!"
Or did MSI [Forgot to say only these M.2-cards match] with a more precise detail?
"No, no they did not!"
And if you´re telling me, none of these M.2-cards fit, then maybe make a damn list about it or better info {MSI}?
If not, I am just marking this [MOBO] as faulty, with all the issues I had with it, even my (MOBO with DDR3 is better built} that costed like 50bucks by that time...
MSI B760...
Part-1: Info…
"No sorry I do not recommend it!"
Why you wonder?
1: M.2:Card has a fit issue & don´t work or want to go into the slot without issues.
ASUS-ROG-MOBO: Had the same issue making people irritated.
So, even with Gen-3 or Gen-4 it, don´t match/fit…
And when I google about it, I am not alone with this faulty-issue.
“I can even see damage on the sides of the card!”
2: The Chassi/Case also have issues with the screws – with a Be Quiet - SHADOW BASE 800 FX Black chassi, this should not be an issue when it´s both E-[ATX] & [ATX]
The MOBO is [ATX]…
That have the right size & the right ATX area & size.
Meaning I had issues putting it in.
Also, the back shield plate, for the USB & other cable areas is garbage.
3: The CPU-cards back plate on mine was also damage.
4: The Pointer for the CPU placed up-side down, with honestly no real good info about it.
Or color marking, so after removing that plate where only the plastic shows the marker & you forgot to think about it, you might put in the [CPU wrongly], honestly no real MOBO marking for the CPU is dumb.
And lastly 5: Not worth the cost, until it dropped down to 150-dollars.
“Still not worth it, looking at this MOBO!”
So, yeah not a card I sadly recommend & that´s probably why it has 3,2 in stars.
Part-2: Then I realize these factory damage: Faulty or badly made MOBO.
1: The M.2:Card 4gen Lightning silver plate do not want to screw in correctly, the plate wiggle.
Removed it took a look & inside the screws holes there was something inside them, like screw damage or something.
Or plastic, honestly…
I took my tech air blower removed it.
Put on the plate, one screw does not want to tighten it.
So, it wiggles & do not want to tighten.
2: I try to removed the CPU holding system, as the screws are so tightly put, I almost thought I screw at the wrong way.
Nopp, someone has honestly tension it so tightly it was scary.
to replace it with a cooling plate, that hold the CPU in place.
What I saw first on the back plate shield was.
1: Damage like little holes on the back, because of the pressure they tighten it & damage on the spikes.
“Why are there even spikes behind the shield back plate?”
[Clearly the card is already damage completely new!]
2: A deep tiny cut on the back shield plate.
As I am thinking “WTF!” I am very careful with my items & carefully handle them & very pedantic so, this is a factory {issue} a faulty or badly made card.
3: I realize weird cuts on the side of the card, like when you cut wood & it becomes like crooked dents.
As I think “This isn´t normal on a MOBO!”
4: The M.2.Cards do not fit, also other say the same & the same with the new ASUS-Rog-MOBO being faulty.
5: The screws holes are like 1/5mm misplaced or something, since the middle hole with the none screw hole make the others holes hard to screw in.
So, yes clearly, I have a faulty or Defective MOBO, still will I buy a new one after this & take the chance the next one is good?
“Clearly no!”
“No I will not!?”
(But I am replacing this garbage card that´s for sure)
And this is why I dislike buying MOBO 2025, the companies that create them create bad & badly ones that´s faulty or just badly made.
They over complicate it & build them wrong :S.
End of story!
CSL & OUT!
