Battery Charge Limit not working
Besferus
Hey.
I’ve set the battery charge limit in MSI Center M to 80%. The Claw keeps charging to 100% though.
I’ve already done a clean install of MSI Center M.
Any ideas of how to fix it?
Edit:
Looks like I've found a solution for my specific issue.
Handheld Companion did indeed mess things up. I had to install it again and activate the battery limit there. After this Battery Master seemed to work again.
I've done a factory reset afterwards to reset all the settings handheld companion has messed up.
Charge limit works as intended now.
It happened after using Handheld Companion.
I guess it messed up the EC.
I made a factory reset after this.
What I’ve done so far:
- reset Bios to optimised settings
- reset EC
- clean installed MSI Center M
Didn’t help. Will calibrate the battery. Hopefully it will fix it.
- reset EC
EC reset Finish condition:The machine cannot be turned on without PD power.
try again........
