Battery consumption when laptop is powered off.
Giosepe
i think i'll try to remove S.O. , trying to see if even in this condition the draining persist.. i don't now if i can see the battery level in the eufi..
Dadudeondacouch
The old saying have you tried turning it off and on again hasn't been a thing for quite a while as doing a shutdown stores the windows kernel in the ram and uses a small amount of power to store it there so the next time you turn the pc on it is already half loaded and takes a fraction of the time to start back up.
If it seems like it's using too much power google how to disable fast startup (fastboot on win 8.1) by doing this windows will clear the kernel and do a full shutdown but will obviously start up a bit slower. You can also check this by starting the pc and opening taskmgr and going to performance then checking the uptime.
muratbeyaz7156702dc
dizüstü bilgisayarımda pil sorunu var, 24 saatte yüzde 20 / 25 yiyor model gl65 9sc i5 9 temiz kurulum yaptım ve işe yaramadı, sonra ejderha dörtnal ayarlarında seçenekler kayboldu
Nichrome
Friday? Deploy to prod!
Try again in English. Final warning.
