Battery current capacity
hi,
my battery current capacity reduced by 4000mWh from 47000mWh to 43000mWh. I don't know whats happening. i recently updated my windows software , it started to deplete fast on from the day. any help
drek4
Active member
PRIVATE FIRST CLASS
hi,
Download HWmonitor and check the WEAR LEVEL of your battery, if less than 40% do a battery calibration and EC RESET if required.
If more than 40%, your battery needs replacement, if under warranty return laptop, if not, order a replacement and do battery calibration every 3 months until replacement required.
cpsoho
FIRST LIEUTENANT
How long do you use your laptop? which laptop do you have?
