Battery Master feature not supported?
seodes105
I am currently using the MSI Alpha 17 C7V model. However, even after reinstalling MSI Center, I cannot find the option to run Battery Master; is this model not supported?
In MSI Center, go to System Diagnosis in Features, check the Battery Master.
If you still can't find it, you can try to refer to the steps in FAQ 4147 and reinstall MSI Center cleanly. Check again.
Can you share the screenshots of the MSI Center version and the missing battery Master interface?
