mark.noh15a702e4
- Feb 12, 2023
Brand new and the Vector GP66 will not charge above 91%
Bad Battery?
Bad Battery?
Bad Battery?
Ok. I unplugged it let it go down to 79%when you got it was it at above 90% Charge if so above 90% the Battery will refuse to take a charge till it drops below 90% to Prevent Overcharging?
if so shut off the AC Adapter and let it discharge while on for about 5-10 mins and then turn back on the AC Adapter so it then charges and then it should go up to 100% but may take some time as its in the very Slow area of Charging as it uses way less current.
Charging again and hopefully that does the trick
Indeed it did charge to 100%
And I got to learn that screen shots now require winKey+FN+PRTSCR, Oy vey can I just have the PRTSCR button default to that, how often does anyone use F12???
ok I'm done whining
Hi. I just got my thin GF63 and it got stuck on 90% while charging for an hour. And here's what it shows in my MSI Center. It's on Best for Mobility but it stuck on 90%. Should I be concerned about this?View attachment 188910
