Best BIOS settings for P67A-C45
VitorMSA
I have a P67A-C45 motherboard with an Intel i5-2500@3.30MHz processor and 4 MB DDR3 1600 MHz.
Could you please tell me the best settings ??in the bios for this configuration?
What is the difference between the intel SVID or APS GreenPowerMode? :think:
Thanks.
Are you intending to overclock or undervolt your system?
If you are not intending to do so, it will be best to remain everything as per stock settings.
I'm not intending to overclock my system. So the optimized default settings from bios are enough???? Intel SVID is better than APS on GreenMode?
Here is a thread that may provide you with some guidance. https://forum-en.msi.com/index.php?topic=147300.0
