tomb2k1156e02d7
- Oct 3, 2022
Hi, I purchased the Corsair a7200 system that is installed with the MSI B550-A PRO motherboard.
The motherboard has 6 SATA data connections and all have been used for SSDs. I've additional 2 SATA HDDs that I would like to install.
The PCI_E4: PCIe 3.0 x1 (PCH) Expansion Slot is available and a PSU connection for power is also available.
Which SATA controllers are would best be compatible so I can add the 2 additional SATA HHDs or are all controllers okay?
Any help would be greatly appreciated.
Thanks...Tom
Thanks...Tom
