best graphics card for this system?
hi. For my system with the following specifications, please introduce a graphics card? What is the best graphics card for this system? or What is the best graphics card for cpu 4790k?
ram 32 g 1600bus (4*8g)
cpu i7 4790k
hard disk 7200 prm 8 t
power 1200w
min biostar z97x
monitor hp ...max. max Resolution 1920*1200 60mhz
What is a graphics card? Which model has less bottlenecks?
darkhawk
Honestly, the old Z97 systems and i7 4790k is finally getting close to the point of upgrading the whole system.
That being said, I think you can still use up to a RTX2080 in it and still get good performance from it.
In the end, this is really more dependent on how much you want to spend the money on.
If it was e, I would probably consider just getting a used 1080 or look into a used RTX card for cheap.
