I'm going to give two examples of why what you think you feel is psychological and not factual. In this first video, Linus shows how it is psychological, and that there is no perceptible difference between the different type of drives. And the kicker is that
every single person in this test chose the
SATA SSD as the fastest perceptible computer and
not either of the computers with NVME drives:
In this second video, the load times of mechanical SATA HDD, a SATA SSD, and NVME SSD are shown side-by-side, and the conclusion is that NVME SSD and SATA SSD are virtually the same speed at loading games:
And there are many more videos where that came from.
So the conclusion is, you can throw all the extra money into NVME drives thinking you will have a faster system, and NVME manufacturers can advertise all the speed in the world, but it's all worthless marketing as
you will not get to experience that extra speed if you're just gaming. You may
think you feel the extra speed, but the actual numbers and real-world tests prove that you're not actually getting those extra speeds.
So it has nothing to do with "to each their own". I guess each person can
psychologically think that they feel the extra speeds (which would in actuality be incorrect), but the actual tests, both human and computerized prove otherwise. I hope that lays to rest this discussion once and for all. I will vehemently rail against people wasting money on NVME drives if all they will be using them for is gaming. The extra money spent on NVME SSD vs SATA SSD and the added heat inside the case from NVME drives is not worth getting almost no extra benefit.
