BETA EC for GT60 0NX (16F3) & GT70 0NX (1762) Laptops (0NE, 0ND, 0NC)
Enoch0
Hi.
Let's say I want to revert back to the original, stock EC.
How do I do that?
cresterk
PRIVATE FIRST CLASS
I flashed T17 version on a gt70 0nd with a 675mx. My gpu VDDC still drops from 1.0370V  to 1.0120V within a few minutes of running a heavy game/benchmark. This stops me overclocking as much as I could as it gives me a display driver failed error when the voltage drops. Can this be fixed using a VBIOS mod?
msigt60
Hi everyone!
Iam  still problem with trottling on my msi gt60....
My spec:
GT60 0NE
MS-16F3
bios ver- E16F3IMS.30O
EC VER- 16F3MS1 VerT.16
The graphics card temps is soo god (no increase of 76 C) but throttling issue present on all temp inc. 45 C! :-(
*Thermal paste and thermopad are change on brand new(mx2)
Please, help...
fowzan
STAFF SERGEANT
hi,
I own an MSI GT70 0nd 202US MS-1762
I have been facing massive fps drops in any game. i usually play CS:GO and BF4. and i experience the same problem in both games. I have tried tons of ways to fix this issue, but nothing has helped me yet.
i will list what all i have tried till now.
1. upgraded from win 7 to win 8.1
2. tried multiple versions of Nvidia drivers 320.49, 326.41 Beta, 327.23, 331.93 and the latest one too 332.21
3. Updated by bios from E1762IMS.10C to E1762IMS.10U
4. Tried unparking the cpu
5. tried emptying the Standby list using RamMap
but nothing has helped at all.
i have created a thread here on the forum with the problem details i am facing. posted a few screens showing the problem as well. https://forum-en.msi.com/index.php?topic=176114.msg1275586#msg1275586
one of the senior forum member has directed me here.
and i hope this can fix my issue.
i do not want to overclock my GPU even to the slightest extent, as i am happy with the performance the gpu gives me.
can someone help me upgrade the EC as i have no idea how to go about with the update. my laptop originally came with win 7 and i have currently upgraded it to win 8.1.
btw my EC version is - 1762EMS1 ver4.05
Administrator
relfash to this one: https://forum-en.msi.com/index.php?action=dlattach;topic=162629.0;attach=10391
For flashing you can >>Use the MSI HQ Forum USB flasher<<,
mode 1 point to bios archive file
when preparation is done, reboot your computer and boot from your USB key,
then pickup option 2. proceed with update
If you have troubles booting from the USB key,
use Tool's "Fix My USB key" option, before the preparation of the USB key
fowzan
STAFF SERGEANT
i downloaded the tool. started the app and selected mode 1.
i tried browsing to the 1762EMS1_T16 folder. but the app doesnt let me select any file. am i doing something wrong?
Administrator
normal.
point to entire archive file, not to specified file from archive,
its looking for either .rar or .zip one as you can see
fowzan
STAFF SERGEANT
got it. Thank you for the help and quick response.
The app was looking for the .zip file and i had to change it to .rar from the drop down menu. sometimes the brain does not want you to proceed without being stupid.
anyways i have done the update. now the EC version is 1762EMS1 VerT.16
I will check if this helps me and post the feedback here.
On an additional note i got 2 BSOD's using this app. hope the feedback helps.
1. If i close the command prompt application without selecting the file in the file browser, a BSOD pops up.
2. after the USB is installed with the EC, the application counts down from 10. and after the countdown a BSOD pops up.
both of these said "BAD_POOL_HEADER"
fowzan
STAFF SERGEANT
back here for the feedback.
THIS THING WORKED AWESOME!!!!!!!!!!!!
Finally fixed the fps issue. now the fps is very stable on BF4 and CSGO. thank you all for the help. just made my day.
on an additional note, can the mods rename the thread and add "FPS DROP FIX" to the thread title.
this fix has solved the prob for many users and there are a lot of guys having this issue with the MSI Laptop. renaming it to something related to the problem would help alot of the guys out there.
wilasek
PRIVATE FIRST CLASS
Hello guys,i have same problem of power throttling in tomb raider 2013.my temp reach 90 graus gpu and cpu 70/73 graus in gaming but i see in fraps 55/60 fraps here but i dont know why keep slow in game.
i have afraid of flash this bios and cause brick system. my notebook is msi gt60 one-403us with gtx 680m and windows 8.the  bios system is E16F3IMS.50U and i never flashed other bios.
out of curiosity I downloaded 16F3.T17 this post and appeared two folders'' win'' and'' dos'', I clicked paste'' win'' and appeared bios and some more files with  the program winflash.exe.i can flash bios for this way from winflash directc in windows 8 or i need flash go in dos using usb pendrive?
somebody help !!
warner please post tutorial i am advice flashing bios
Administrator
you can flash it within windows too
wilasek
PRIVATE FIRST CLASS
i have fear of brick!i have experience with alienware and have solution easy if brick with bios of system,just put bios in pendrive and press button end and power laptop and start process of flashing but msi i dont have knowledge if have some solution of brick.
you have experience with flashing bios in gt60 one svet?in this post of warner he only speak about flashing dos,because i am here.
i see that warner not more reply in this post for one time,you have contact with him?can ask him for help!!i am very dissapointed with this product,i cant play any game without throttling
thx very for help!!
wilasek
PRIVATE FIRST CLASS
the bios that i need do download is this 16F3.T17?is right?i am using windows 8,the bios that i am using is above and model too.
this bios resolve my problem?i need do overclock to use this bios of warner?
Administrator
EC Versions T16 are Win7 EC
EC Versions T17 are Win8 EC
no
krisg
hi how can i tell which EC Version i should use?
I am running Windows 8.1 Pro, but in the battery compartment i see a Win7 sticker, does that mean im in a Win7 EC model?
My laptop is MSI GT60-2Ok 3K
thanks in advance for helping
niifelix
My MSI GT60 0NE came pre-installed with windows 7. I have upgraded to windows 8.1 and want to run an Ubuntu 64 bit using virtual box. However, it seems virtual is disabled and can only install 32 bit Ubuntu. I was able to run Ubuntu 64bit using windows 7. How can I fix this? This is my cpu report:
BIOS Version: E16F3IMS.10U
EC: 16F3EMS1.T17
Intel(R) Processor Identification Utility
Version: 4.80.20131220
Time Stamp: 2014/01/31 23:10:09
Operating System: 6.2-9200-
Number of processors in system: 1
Current processor: #1
Active cores per processor: 4
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Type: 0
Family: 6
Model: 3A
Stepping: 9
Revision: 17
Maximum CPUID Level: D
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache: 4 x 256 KB
L3 Cache: 6 MB
Packaging: ?PGA/BGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: No
Intel(R) VT-x with Extended Page Tables: No
System Graphics: Intel(R) HD Graphics 4000
Expected Processor Frequency: 2.30 GHz
Reported Processor Frequency: 3.09 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
