BETA-Releases for H61MU-E35, H61M-E33, H61M-E23 & H61M-P33 [MS-7680 v2.0/2.1]
Jack the Newbie
GENERAL OF THE ARMY
I will upload the latest BETA-UEFI-Release(s) for the E7680IMS.Axx-Release Series [v10.xx] here.  These Releases are for the following mainboard models only [MS-7680 PCB v2.0 / v2.1 -> ERP 030, 040, 060 and 070]:
- H61MU-E35
- H61M-E33
- H61M-E23
- H61M-P33
The latest release is E7680IMS.A41 [=v10.4b1].
Changelog:
E7680IMS.A30 ---> E7680IMS.A41
- Add LowMemory Support.
- Add AHCI Support.
---> Modify Remove SATA PORT3/4 to Hidden SATA PORT3/4.
---> Remove check Bom For USB3.0 varstore to Chipset.vfr.
---> Add Check Hot Plug Port1/port2 For H61M-P33.
- "H/W Monitor" to "Hardware Monitor"
- Add "Intel VT-D Tech" in OC\CPU Features page
- Correct disable USB Controller cannot into S3/S4.
- Patch the ATI 6xxx VGA card installing VGA driver after the OS halted.
- Fixed When installing 3TB HDD and then press F11 to select UEFI DVD, the system will hang in blank screen.
- Fixed MFLASH in setup recovery Fail.
As always, use this release at your own risk!
>>Use the MSI HQ Forum USB flasher<< [Method II] for safer flashing and best results.
  • E7680IMS.A41.rar
I have assembled a PC with the H61M-E33 board and i3 2100 CPU.  I can get into the BIOS and generally things seem OK at this point.
But I have the issue in the BIOS where ACHI cannot be selected.  So I need to update the BIOS, to enable selection of ACHI.  But I am confused about which BIOS I should use.  You mention the E7680IMS.A41 Bios which you link to in your post.  But also I see a BIOS file called 7680vA4.zip with a release date of March 31, located here:
http://www.msi.com/product/mb/H61M-E33--B3-.html#?div=BIOS
So I am wondering, does the 7680vA4.zip contain the ACHI changes, or should I instead use the BIOS you referenced?  I am wondering which is the most current?  Thanks for any assistance.
- Add AHCI Support.
I would use the one Jack has linked. It is specific in the change log to have the AHCI feature added.
HU16E said:
- Add AHCI Support.
Yeah, that is why I was concerned, because the other BIOS update that I had linked to (which if I am not mistaken is the more "official" released MSI BIOS update), did not mention the ACHI change.  I think that I will install the BIOS version mentioned by Jack.  Thanks.
The final .A40 [v10.4] release is based on the v10.4b1 release I have uploaded above.  The final release is, of course, newer and it includes all fixes implemented in v10.4b1.
Changelog:
E7680IMS.A41 --> .A42 --> .A43 ---> .A44 ---> E7680IMS.A40
- Modify some setup string/option
- Change the Package C State limit item default value.
- Fix Resume From S3 by PS/2 Mouse Disabled Function fail
- Add new module, SmiVariable and "ALWAYS_PUBLISH_HII_RESOURCES"=1 for WMI function
- Add'CPU Phase Control' item
- Fix DRAM Timing not match SPD value
- Fixed the system will hang in blank screen when press F11 to select UEFI DVD installing 64Bit OS issue.
- Fix usb mouse(RAZER COPPERHEAD RZ01-050200/RAZER DeathAdder RZ01-0015/RAZER COPPERHEAD RZ01-050100/Steelseries IKARI OPTICAL mouse, 62000/Steelseries KINZU OPTICAL mouse, 62011)Issue in bios setup menu
Will this work on the H61M-P23
No!  The H61M-P23 uses E7680IMS.Hxx releases.  Please consult the following thread for BETA releases for the H61M-P23:
https://forum-en.msi.com/index.php?topic=147964.0
Back to topic [H61MU-E35, H61M-E33, H61M-E23 & H61M-P33 BETA [MS-7680 v2.0/2.1]:
Update: E7680IMS.A53 [v10.5b3]
E7680IMS.A40 ---> E7680IMS.A53
- Add VGA Share Memory Option Name "256M/512M/1024M"
- Add SYS Smart FAN Function for PCB2.1.
- Adjust USB3.0 SMI GPI 11 to 14 for PCB2.1
- Remove "USB 3.0 Legacy Mode Support" for some BOM(No USB 3.0 Port)
- Remove VGA Share Memory Option Name "256M/512M/1024M" for ECN
- Fix plug 4 dimm G-Skill F3-12800CL7D boot fail when XMP enabled
- Temporarily closed SmiVariable Function for M-Flash Boot Issue.
>>Use the MSI HQ Forum USB flasher<<, Method II for best results.
Use this release at your own risk!
  • E7680IMS.A53.rar
Changelog:
Hey!
I know it's been a long time, this could seem weird.
So across all the internet I quasi found just your post about the topic I'm interested in: SmiVariable and "ALWAYS_PUBLISH_HII_RESOURCES"=1 for WMI function
I need to do the same for my BIOS and I was hoping you could help me with that, because after a long time I finally found somebody mentioning it.
Thanks in advance!
