stephankaiser8156202dc
- May 20, 2022
Hey everyone, today i build my new pc and when I try to use any USB device in the BIOS it crashes.
The problem
The system loads into the BIOS as it should and all components are recognized (CPU/RAM/M.2) but as soon as i use my keyboard or mouse there is a short lag then the cursor moves and then the BIOS crashes. The screen turns black, shows no signal and the kb and mouse turn off, the fans of the computer stay on. After a few seconds the kb and mouse turn back on and the BIOS screen comes back, if I use my kb or mouse again it lags and crashes again. Sometimes I can navigate through the BIOS for a few seconds but it eventually crashes. (it crashes faster when I use the mouse and works a little longer using kb) It also crashes when I start up with a bootable Windows USB-stick in. When I don't do anything the BIOS stays on forever and doesn't crash (with multiple USB devices connected) but as soon as I use my kb or mouse it crashes.
The system
CPU: AMD Ryzen 5 5600G
Motherboard: MSI B550M PRO-VDH WIFI
BIOS: E7C95AMS.280 (06.22.2021)
RAM: 16GB (2x 8GB) G.Skill Aegis DDR4-3200 CL16
M.2: SAMSUNG SSD 980 500 GB
PSU: 500W Seasonic
Case: Aerocool Trinity Mini-G-BK-v2
What I've tried
XHCI hand off and legacy USB support are enabled, I was able to check that just before it crashed. I don't have a keyboard or mouse with PS2 plug.
The only thing that I can think of that is left is updating the BIOS. However I am hesitant to try that since it uses USB and if it's a USB issue it might crash and brick the system.
I hope someone has experience with this issue and can help. Thanks in advance.
The problem
The system
PSU: 500W Seasonic
What I've tried
- - different keyboards and mice (both wired and wireless, they all work fine on my other system)
- - only connect one USB device at a time (kb OR mouse)
- - every USB port
- - different display connections (DP&HDMI)
- - cleared CMOS
- - disconnected front USB
- - checked all cables
