Bios flashed but cpu smart light still on
i went to flash the bios cause i just got a 3600 and the bios light flashed for 5 mins just as normal, computer power cycled and is now running with no display showing. The cpu light remains on.
Please list all your components, or should we guess your mainboard model?
B550 bazooka
Ryzen 5 3600
AMD 6800XT
Trident Z NEO 32gb (8x4) 3600mhz CL16 ( i believe)
Samsung 1TB m.2 (cant remember specific one at this moment)
Kingston 960GB ssd
Seagate 2TB
Also, sorry, busy day/night
Ok. What's your PSU?
The B550 Bazooka supports the 3600 by default, so it should've at least started with it. Then you could've updated the BIOS using M-FLASH from the BIOS, which is always the best option if your CPU is already supported by the previous BIOS. How did you flash the BIOS, did you use the Flash BIOS Button? Then maybe it didn't work correctly, so you might have to try to flash it again until it works.
First you can try a Clear CMOS by bridging two pins with a screwdriver (the manual explains where the pins are).
Then try flashing again with different USB sticks. Do it exactly by the instructions.
Download the newest beta BIOS (topmost one when clicking on BIOS): https://www.msi.com/Motherboard/support/MAG-B550M-BAZOOKA#down-bios
Format the USB stick as FAT32 non-bootable with the help of https://rufus.ie/en/ (i would use this tool, it has more of chance of working than letting Windows format it).
