Beta BIOS for MPG X870E CARBON WIFI
Beta BIOS/FW/Software
ADMIN
>>> E7E49AMSI.1A1E <<<
>>> E7E49AMSI.1A1H <<<
>>> E7E49AMSI.1A21 <<<
>>> E7E49AMSI.1A22 <<<
>>> E7E49AMSI.1A24 <<<
>>> E7E49AMSI.1A25 <<<
>>> E7E49AMSI.1A26 <<<
>>> E7E49AMSI.1A28 <<<
>>> E7E49AMSI.1A29 <<<
>>> E7E49AMSI.1A31 <<<
>>> E7E49AMSI.1A32 <<<
>>> E7E49AMSI.1A33 <<<
>>> E7E49AMSI.1A34 <<<
>>> E7E49AMSI.1A41 <<<
>>> E7E49AMSI.1A44 <<<
Notes:
  • * Unstable RAM OC
>>> E7E49AMSI.1A62 <<<
>>> E7E49AMSI.1A65 <<<
>>> E7E49AMSI.1A66 <<<
>>> E7E49AMSI.1A93 <<<
>>> E7E49AMSI.1A99 <<<
.rar SHA-256: 0da3ebedfa9e1f53f3e3aa320c1fd32f770cae0b32f112fe87750f1f88031487
BIOS SHA-256: 07a227bb302e9eac43bca0e18a43cfe58e043302eebfb13b08c7b8653a8ad636
>>> E7E49AMSI.1AA1 <<<
.rar SHA-256: cf63c3ad59580532257612b108db651ec3341a517c22efb20127dd44c94d8ae1
BIOS SHA-256: 4BD52D73DE3112768E2C6C62CA85C423F0963359A4C4B1CFCFEF1C04294DE1D2
AGESA version:
>>> E7E49AMSI.1A9B <<<
.rar SHA-256: 9eae3f5df43c2696e64ef329c6fddc45ba2e40ec0b529a9c451fa3871b077bff
BIOS SHA-256: 2B34A9B25DDEC186AC2272334DC2666C80082B143468A4D9D470BE88AB2C4CB4
AGESA version:
>>> E7E49AMSI.1AA2 <<<
.rar SHA-256: 3e1eec8ecdd717f7b694f7a82e704d4fb7ef54ad4f357fe5e28de6b9de422473
BIOS SHA-256: B1172777823B553168B6B1A14C57CAF7E7B48C259EBC43586B39C2A9BC4C8542
AGESA version:
Latest version: (from msi web page)
7E49v1AA3:
BIOS SHA-256: AF55A578CBDE8138906094F1CAD8C4C6A06639C4DAB23C0D7ACEA392326847AA
AGESA version:
>>> E7E49AMSI.1AA4 <<<
.rar SHA-256: 501a027d7cc8d1016f0164a0e7ec5a5f1cf39a32c13ad90af2c70e3dc90bfce2
BIOS SHA-256: 2A98DA827D82FF800397AF901680995D5481DC7DE8D62BAB6890DB9119C472F7
AGESA version:
7E49v1AA7:
BIOS SHA-256: 060DCBFB7B80454820B56418A55255BEF9E79686C6CF43D1522D015AA5B82CFE
AGESA version:
FYI:
With >>Forum UEFI Shell Flash & Patch Tool<<
you can copy the generated hash of the BIOS file quickly,
by loading the BIOS and click over BIOS-SHA256 on the bottom:
then in this topic you can do press CTRL+F in your web browser,
paste the contents to check if will match it.
Aside from this you can check AGESA version of the BIOS File,
and / or let the tool prepare the USB key for flashing
either by the tool by booting from USB key or by M-Flash.
While doing USB key preparation with the tool,
it will ensure the BIOS File's integrity on the USB key of both Checksum and SHA256.
This also will ensure your USB key used is not damaged or corrupted prior flashing
regardless of the flashing method.
_
I was able to fix the stuttering by setting the power management setting in windows to balanced and specifically the pci express setting set to maximum power savings.
I upgraded, changed my 9950x to 9950x3D. I cleared the CMOS, installed the a29 BIOS. Every time the PSU is disconnected from the mains power, the computer does not turn on (error C5, OA, and Ab). To be able to turn it on, I have to press the Safe Boot button on the motherboard a few times, until the OA code appears, then wait almost 2 minutes to start training the memories. I decided to change a setting in the memory and it seems to have worked (activate Power Down, as it was disabled). This behavior was not observed with the 9950x processor and happened with my 9950x3D.
After some tests I realized that the processor doesn't show all its strength, because I can only get 890 points in single core on CPU-z, while some get 909. The same thing happens in CB23, I only get 45500 points and some get 46800. Maybe it's some limit that doesn't let the EDC go up, nor the PPT. While I only spend 230w, other people have better performance and use up to 300w.
Edit: By pressing the "Smart Button" on the back of the motherboard, I can enter "Safe Boot" mode. It's awful having to do all this ritual to be able to boot.
Ugh, that does sound frustrating. I'm considering upgrading to a 9950x3d myself but have held off until I get this board working perfectly with the 9800x3d. I'm doing some production workloads but not enough to REALLY see the benefit just yet, and it's more important than I upgrade from my 3090 - once friggin' GPUs actually come to market in enough quantities that I'm not paying a scalper.
Give dropping your RAM down to 6000MT/s a try. The IMC on the x3d processors is MUCH more sensitive to frequency, it appears, but doesn't NEED as fast RAM with the 3d vCache. Until I scaled my 8000 MT/S RAM back manually, I was seeing a LOT of this sort of bug on startup/restart/etc.
Setting the power management setting to Balanced does improve performance, specifically on dual CCD chips (so the scheduler works properly), but setting the PCI Express P/S to "Maximum" does seem like an odd setting for performance...
Seems official A30 Bios is up but under the wrong name A3. Inside the zip file, the BIOS file name extension is A30 as expected. Anyone tried it?
That is interesting. I hadn't noticed any suspicious CPU information being incorrect on my 9800x3d, so I suspect that it's mostly for the 9900x3d and 9950x3d's. Other patch notes seem identical to A27. Haven't tried A30 yet, but A29(beta) seems really solid on my test machine. Still going through testing on mu per-core undervolting but maybe I'll upgrade in the meantime just to get it on an "release" version.
No idea if there was anything addressed with what some folks are seeing, with the E1 PCIe socket getting stuck at lower versions than it should be, or if there are any speed increases on M2_1 and M2_3. I'll test the M2 slots and get back to everyone if there's any difference there, but A29 was actually a slight regression on that front.
I reduced it to 6000Mts, same behavior. Then I swapped the slot memories, one for the other. First boot was good, I will continue testing.
I updated to the new A30 from the original 1A10 today. Cleared CMOS before BIOS update and did the same after the BIOS update before i started making any changes.
I lost a lot of undervolt stability... I was stable at -30 on old BIOS. Tried -20 and windows froze while booting. Ended up stable at -15
Memory EXPO setting took without issue (6000mhz CL 30-36-36-80 @ 1.4v)
Not having any stuttering issues
Wi-Fi, Bluetooth, etc.. seem stable so far
No issues so far with my 5070 Ti and from what I'm reading that's a miracle in itself..
When running Cinebench r23 @ -15 undervolt, CPU VDDCR_SOC hit max 1.190v and hit max temp of 86.5c
While gaming, temps are much lower.. not seeing anything higher than 60c max
EDIT:
Cleared CMOS 3 more times using the button on the MB just to make sure the BIOS update didnt hang onto any old crap.. and low and behold im back to a stable -30 undervolt. Max temps in Cinebench r23 dropped a few more from 86.5c to with -15 to 83.2c with -30 undervolt. sitting at 39c idle
System:
9800X3D (using Thermalright Phantom Spirt 120 SE Air cooler)
MSI x870e Carbon
Kingston Furry Beast CL30 Ram (A-die) - 6000mhz CL 30-36-36-80 @ 1.4v
Asus Tuf 5070 Ti OC
2tb Samsung 990 Pro (NVMe 1), 2tb Samsung Evo Pro (NVMe 3), 4tb Samsung Evo Pro (NVMe 4) - Nothing in NVMe slot 2 to avoid GPU lane sharing
Corsair RM1000x
CrystalDiskMark - NVMe slot 1 with Samsung 990 Pro:
Read (MB/s)Write (MB/s)
SEQ1M / Q8T17387.356910.88
SEQ128K / Q32T17363.956834.77
RND4K / Q32T165739.495514.81
RND4K / Q1T175.97253.66
EDIT:
System:
MSI x870e Carbon
Asus Tuf 5070 Ti OC
Corsair RM1000x
How about your cinebench scores are they on par with prior version? I do ask because I m used to see a little regression with each bios release , on single and multithreaded benchmarks.
it doesn't affect performance, I was getting "hitching" in Windows just watching movies, idk if it was because I had my power setting to Maximum or what but I read that the pci-setting to minimum stops the hitching. So I did both of that and it stopped.
I had no progress, because on the third boot the problem returned. So if I disconnect the computer from the power and turn it back on after 3 minutes, for example, the boot works, but if I wait about 2 hours to turn it on, the boot doesn't happen (error OA or 15). I'm suspecting it's the pressure in the socket, but if I ease the pressure a little more, I get error C5.
On another note, just FYI, if you're using A29 along with AMD overclocking's "Auto Voltage" setting while overclocking the CPU with BCLK, pay close attention to the voltage set by the motherboard.
To my great surprise, I saw a whopping 1.394V at 4911 MHz (104.5 BCLK), something I never saw with any prior BIOS versions A21 - A26, where the voltage maxed out around 1.25-1.31V
Good info to watch for, thanks. I played around with BCLK a little on my test system and it seemed stable on A29, but didn't push anything past 101. Went back to base 100 while testing per-core CO. Are you able to stabilize it by fixing the VCORE to 1.31V or is it still bouncing around when testing?
EDIT:
System:
MSI x870e Carbon
Asus Tuf 5070 Ti OC
Corsair RM1000x
I have gotten -30 undervolt stable on many of my cores while others are stuck around -15. How are you testing to confirm stability other than booting? My system would often boot at -30 but I'd start to get errors that impacted latency, causing momentary freezes. The thing that I'm using now is Aida64 with FP checked while checking CPU, Memory and Cache. I'm counting 8-9 hours per test without an error as "stable" and with undervolting, I'm sometimes seeing failures running those settings after 5 hours. Saw one of my cores that I was testing at -34 this morning (that passed -30, it's testing now at -34) fail after 5 hours, 43 minutes of testing.
Two of my cores are stable at -35, but I don't think I'll push them any further. It's an eclectic mix of numbers.
My plan is to create processor sets in Process Lasso and run different games/processes that need performance under those core sets, while others that need less performance (web browsing) run on the less-performant cores.
You are definitely running your tests longer than me. For stability I run 2 hour long cinbench r23 multi core, memtest, and Aida64. I played black myth wukong for 5 hours today and didn't have issues either. I don't stress test too much.. maxing out the system for 8-9 hours isn't the same load my system will see when im playing games anyway. In fact, most games I'm seeing 20-40% CPU utilization while the GPU sits much higher. Gaming does not heat up the CPU anywhere near stability testing either. While gaming the CPU runs about 20-25c cooler
My Cinebench scores have been fairly stable. Multi Core always in between the 23-23.5k range. Single core between the 2k-2.15k range. I'm also just undervolting.. no overclock.
You'll definitely see lower temps during gaming, you won't be processor limited unless you're gaming at 1080p. So that's definitely expected behavior. Cinebench is a great benchmark but doesn't really do stress testing as it won't report errors. If you're mostly gaming this probably won't ever matter so long as you're not experiencing crashes or freezes.
I don't do a huge amount of production workloads, but when I do I can't afford random errors in calculations.
Can you run Samsung's performance tests from within Samsung Magician on your 990's? I don't think we have numbers from A21 in CrystalDiskMark to compare them to.A30, and they use different metrics for random IOPS.
