Beta BIOS for MPG X870E CARBON WIFI
Beta BIOS/FW/Software
ADMIN
>>> E7E49AMSI.1A1E <<<
>>> E7E49AMSI.1A1H <<<
>>> E7E49AMSI.1A21 <<<
>>> E7E49AMSI.1A22 <<<
>>> E7E49AMSI.1A24 <<<
>>> E7E49AMSI.1A25 <<<
>>> E7E49AMSI.1A26 <<<
>>> E7E49AMSI.1A28 <<<
>>> E7E49AMSI.1A29 <<<
>>> E7E49AMSI.1A31 <<<
>>> E7E49AMSI.1A32 <<<
>>> E7E49AMSI.1A33 <<<
>>> E7E49AMSI.1A34 <<<
>>> E7E49AMSI.1A41 <<<
>>> E7E49AMSI.1A44 <<<
Notes:
  • * Unstable RAM OC
>>> E7E49AMSI.1A62 <<<
>>> E7E49AMSI.1A65 <<<
>>> E7E49AMSI.1A66 <<<
>>> E7E49AMSI.1A93 <<<
>>> E7E49AMSI.1A99 <<<
.rar SHA-256: 0da3ebedfa9e1f53f3e3aa320c1fd32f770cae0b32f112fe87750f1f88031487
BIOS SHA-256: 07a227bb302e9eac43bca0e18a43cfe58e043302eebfb13b08c7b8653a8ad636
>>> E7E49AMSI.1AA1 <<<
.rar SHA-256: cf63c3ad59580532257612b108db651ec3341a517c22efb20127dd44c94d8ae1
BIOS SHA-256: 4BD52D73DE3112768E2C6C62CA85C423F0963359A4C4B1CFCFEF1C04294DE1D2
AGESA version:
>>> E7E49AMSI.1A9B <<<
.rar SHA-256: 9eae3f5df43c2696e64ef329c6fddc45ba2e40ec0b529a9c451fa3871b077bff
BIOS SHA-256: 2B34A9B25DDEC186AC2272334DC2666C80082B143468A4D9D470BE88AB2C4CB4
AGESA version:
>>> E7E49AMSI.1AA2 <<<
.rar SHA-256: 3e1eec8ecdd717f7b694f7a82e704d4fb7ef54ad4f357fe5e28de6b9de422473
BIOS SHA-256: B1172777823B553168B6B1A14C57CAF7E7B48C259EBC43586B39C2A9BC4C8542
AGESA version:
Latest version: (from msi web page)
7E49v1AA3:
BIOS SHA-256: AF55A578CBDE8138906094F1CAD8C4C6A06639C4DAB23C0D7ACEA392326847AA
AGESA version:
>>> E7E49AMSI.1AA4 <<<
.rar SHA-256: 501a027d7cc8d1016f0164a0e7ec5a5f1cf39a32c13ad90af2c70e3dc90bfce2
BIOS SHA-256: 2A98DA827D82FF800397AF901680995D5481DC7DE8D62BAB6890DB9119C472F7
AGESA version:
7E49v1AA7:
BIOS SHA-256: 060DCBFB7B80454820B56418A55255BEF9E79686C6CF43D1522D015AA5B82CFE
AGESA version:
FYI:
With >>Forum UEFI Shell Flash & Patch Tool<<
you can copy the generated hash of the BIOS file quickly,
by loading the BIOS and click over BIOS-SHA256 on the bottom:
then in this topic you can do press CTRL+F in your web browser,
paste the contents to check if will match it.
Aside from this you can check AGESA version of the BIOS File,
and / or let the tool prepare the USB key for flashing
either by the tool by booting from USB key or by M-Flash.
While doing USB key preparation with the tool,
it will ensure the BIOS File's integrity on the USB key of both Checksum and SHA256.
This also will ensure your USB key used is not damaged or corrupted prior flashing
regardless of the flashing method.
_
Thx.
PS. After installing Realtek PCI-E Ethernet Drivers10.79.50.1003 my WIFI does not work.
After restoring the old driver 10.74.1128.2024, everything works fine. What's next?
"Svet obviously pulled them...." obviously we ended up in some misunderstanding, for me 75 was the one that caused all issues released by MSI. What SVET is releasing isn't OFFICAL on any page therefore not subject to complain, OK?
About not working in LINUX is really not my field or interest all I know 79 works normally like 64 before. The person stating "Bios A71 can't boot, so "Happy Birthday broken bios [A71,A75,A78,A79]"" I just noticed that's too many bios' versions not working and not all are bad for F sake.
As 79 under Win 11 pro environment and my hardware combination works without issues, I have no reason to flash back to 64 I'll just wait for another release but with current "successful" (not counting SVET releases) records God knows when this will be, AMD same as MSI really sinking low in reliability.
Yeah, know anything on this thread is not official, I just wanted to make sure I wasn't missing something and it was posted elsewhere as working. Hoping that clarification would help others too.
We never got clarification in exactly why it was pulled. Someone speculated it was because of the AMD microcode bug that effected linux and generators in 16 and 32 bit. That wouldn't necessarily impact Windows 11, and that's what I was saying - might not effect your uses, but still be classified as "broken". Didn't mean to sound like I was challenging or insulting you personally, just looking for some clarification that is so often in short supply from MSI officially or unofficially these days. Sorry there was some miscommunication there, it can be hard to convey intent through forum posts.
How do I set +200 Core? I haven't played around with OC yet.
The 9800X3D is actually the first X3D chip that’s fully unlocked because AMD put the cache under the cores this time for better cooling. To get that +200 boost, just go into BIOS, then OC -> Advanced CPU Configuration -> AMD Overclocking and set PBO to Advanced. Look for Max CPU Boost Clock Override, set it to Positive and type in 200.
I’m running the same CPU/Board combo and I recommend combining that with Curve Optimizer set to Negative (start with -20). It helps with temps and lets the boost hit 5.4GHz more easily. Just keep in mind that at the end of the day, it all depends on your specific CPU and the silicon lottery-not every chip will handle the same settings
I would even say start with -10 these days. My 9950x3d has a couple of cores on it that get unstable at -20 after a few hours of stress testing. I haven't gone deep enough into per-core in a while, since the BIOS was changing so often in the past year and it basically invalidates any curve optimization/curve shaping work, and takes hours to truly test a configuration. Maybe I'll pick it up again once I decide to take the plunge and install the new official BIOS... after it's been up a week or two. :D
Currently I've got it set at -15 all-core, and stays stable there even after long gaming sessions, and that's all the frustration I can handle right now.
Try per core -35 from cores 0 - 7. For the rest, leave them 0. It worked for me here
Yeah, all going to depend on the silicon lottery, and the 9950 is a 2-CCD solution, so 2x the odds. It's really performant without dipping too far, though I know it could be more performant if I had time to really tune it.
I've spent days of cumulative time tuning it only to have a new BIOS update throw those results out and having to start over again. WAY more fragile settings-wise than anything before it.
Which driver are you using? The link leads to a driver package.
Meant to post an answer to this and forgot... you can download the RealTek NIC drivers directly from RealTek to get the latest and greatest, since the board vendors seem to be fairly behind sometimes. Here's a link to their driver page:
https://www.realtek.com/Download/List?cate_id=584The "no support power saving" drivers are the ones I use, though not necessary - just ensures the NIC won't be randomly powered down to sleep (seems to be a problem with Windows not sure what hardware is safe to do so).
NDIS is for Windows 10 and contains some built-in driver information, so will still work on Windows 11. The NetAdapterCX drivers are the ones specifically for Windows 11, and (essentially) use Windows 11's built-in network stack so should be more compatible with other hardware. I have had some issues with the NetAdapterCx drivers before, so it's good to have options. The 11.027.20 NetAdapterCX drivers have worked fairly well for me.
...I'm always a bit nervous about installing drivers from 3rd party "driver archive" sites, unless you have a known good hash to compare it to. Who knows what's been "added" to those drivers before being uploaded?
(Additional note: Realtek doesn't post their modern audio drivers and only updates system vendors with those. These drivers are their network adapters only.)
Hi guys, a quick explanation regarding the NetAdapterCx network drivers you might see for Windows 11. NetAdapterCx is the modern driver framework from Microsoft designed to replace the old NDIS standard. It is more efficient because it offers better power management and faster performance by reducing system overhead. If you are running Windows 11 and see this version available on the MSI support page, I recommend picking it over the legacy drivers since it is more stable and specifically optimized for the newer OS
After updating the BIOS to A7C, I noticed something quite interesting.
My configuration is:
  • Memory: EXPO 6000 C28
  • CPU: +200 MHz, 10X scalar
  • Thermal limit: 95°C
  • Curve Optimizer: CCD0 -30, CCD1 -25
Under A64, both CPU voltage and temperature are noticeably lower compared to A7C.
In AIDA64, CPU temperature stays around 48°C on A64, while it exceeds 50°C on A7C under the same workload.
More importantly, memory latency differs significantly:
A64: ~65 ns
A7C: ~69 ns
After testing, I rolled back to A64 again. Based on thermals, voltage behavior, and memory latency, A64 is still the better choice for my setup.
Will have to try this tonight had to go back to 64 it downclocks my gpu to 8x don't know why that is happening never had it on 64. When I go back it works.but it only downclock on some cold boot.other then that it works good.
Hi guys,
I've just flashed the new 7E49v1A7D BIOS on my MSI X870E Carbon WIFI and I’m impressed with the results so far.
The main thing I’ve noticed is a solid boost in memory performance. My RAM benchmarks are showing higher read/write speeds, and the memory latency has dropped significantly compared to the previous version. The system feels very snappy and stable.
It's great to see MSI providing these optimizations so quickly. For anyone wondering whether to update, the memory improvements alone make it worth it in my opinion.
(You can see my full specs in my signature below.)
Cheers!
"It's great to see MSI providing these optimizations so quickly" not really and don't worry MSI has the trend to fckup things immediately after the next release. MSI is usually one step forward, 2 steps back, consistency is not their virtue.
Fair enough, I know everyone has different experiences with BIOS stability over time. I can only speak for this specific release and, at least on my end, the performance gains are measurable and the system is stable for now. Hopefully, they keep this momentum and don't take those 'two steps back' with the next one:)
