Beta BIOS for MPG X870E CARBON WIFI
Beta BIOS/FW/Software
ADMIN
>>> E7E49AMSI.1A1E <<<
>>> E7E49AMSI.1A1H <<<
>>> E7E49AMSI.1A21 <<<
>>> E7E49AMSI.1A22 <<<
>>> E7E49AMSI.1A24 <<<
>>> E7E49AMSI.1A25 <<<
>>> E7E49AMSI.1A26 <<<
>>> E7E49AMSI.1A28 <<<
>>> E7E49AMSI.1A29 <<<
>>> E7E49AMSI.1A31 <<<
>>> E7E49AMSI.1A32 <<<
>>> E7E49AMSI.1A33 <<<
>>> E7E49AMSI.1A34 <<<
>>> E7E49AMSI.1A41 <<<
>>> E7E49AMSI.1A44 <<<
Notes:
  • * Unstable RAM OC
>>> E7E49AMSI.1A62 <<<
>>> E7E49AMSI.1A65 <<<
>>> E7E49AMSI.1A66 <<<
>>> E7E49AMSI.1A93 <<<
>>> E7E49AMSI.1A99 <<<
.rar SHA-256: 0da3ebedfa9e1f53f3e3aa320c1fd32f770cae0b32f112fe87750f1f88031487
BIOS SHA-256: 07a227bb302e9eac43bca0e18a43cfe58e043302eebfb13b08c7b8653a8ad636
>>> E7E49AMSI.1AA1 <<<
.rar SHA-256: cf63c3ad59580532257612b108db651ec3341a517c22efb20127dd44c94d8ae1
BIOS SHA-256: 4BD52D73DE3112768E2C6C62CA85C423F0963359A4C4B1CFCFEF1C04294DE1D2
AGESA version:
>>> E7E49AMSI.1A9B <<<
.rar SHA-256: 9eae3f5df43c2696e64ef329c6fddc45ba2e40ec0b529a9c451fa3871b077bff
BIOS SHA-256: 2B34A9B25DDEC186AC2272334DC2666C80082B143468A4D9D470BE88AB2C4CB4
AGESA version:
>>> E7E49AMSI.1AA2 <<<
.rar SHA-256: 3e1eec8ecdd717f7b694f7a82e704d4fb7ef54ad4f357fe5e28de6b9de422473
BIOS SHA-256: B1172777823B553168B6B1A14C57CAF7E7B48C259EBC43586B39C2A9BC4C8542
AGESA version:
Latest version: (from msi web page)
7E49v1AA3:
BIOS SHA-256: AF55A578CBDE8138906094F1CAD8C4C6A06639C4DAB23C0D7ACEA392326847AA
AGESA version:
>>> E7E49AMSI.1AA4 <<<
.rar SHA-256: 501a027d7cc8d1016f0164a0e7ec5a5f1cf39a32c13ad90af2c70e3dc90bfce2
BIOS SHA-256: 2A98DA827D82FF800397AF901680995D5481DC7DE8D62BAB6890DB9119C472F7
AGESA version:
7E49v1AA7:
BIOS SHA-256: 060DCBFB7B80454820B56418A55255BEF9E79686C6CF43D1522D015AA5B82CFE
AGESA version:
FYI:
With >>Forum UEFI Shell Flash & Patch Tool<<
you can copy the generated hash of the BIOS file quickly,
by loading the BIOS and click over BIOS-SHA256 on the bottom:
then in this topic you can do press CTRL+F in your web browser,
paste the contents to check if will match it.
Aside from this you can check AGESA version of the BIOS File,
and / or let the tool prepare the USB key for flashing
either by the tool by booting from USB key or by M-Flash.
While doing USB key preparation with the tool,
it will ensure the BIOS File's integrity on the USB key of both Checksum and SHA256.
This also will ensure your USB key used is not damaged or corrupted prior flashing
regardless of the flashing method.
_
Hi @Svet, any chance you could also share a beta bios for X870E Tomahawk Wifi with Agesa 1.3.0.1 please?
I've not been able to stabilize my DDR5-8000 profile with 7E59v2AA0/7E59v2AB0, but works absolutely fine with 7E59v2A90
Hello there.
Excuse me, but could someone post a quick changelog between latest stable 1A95 and latest beta 1A99? I'm interested about the memory changes and the AGESA version.
Thank you!
The main jump is from AGESA 1.3.0.0 to 1.3.0.1. The 1A99 version is basically a fix for the memory issues in the previous 1A98 build, which was causing boot failures and post codes 00/02 for some of us. It feels more stable for memory training now, but keep an eye on your Auto voltages as they might run a bit higher than before. Definitely a solid update over 1A95 if you're looking for better stability
Thank you!
A99 runs without issues on my system 9850X3D 8000Kingston FuryLE I'm also able to use tighter settings and have no issues, as for autoPWR works pretty good with 9850X3D and I always under volt SOC to 1.25 as it is set to 1.3 by Bios and still have the memory stable . So overall coming from 95 to 99 I see no significant performance difference here I'm stable at Curve -25 while on 95 I could go only -20 +200 Boost. However, I see no significant difference in performance, if it doesn't run worse after update, I take it as good regardless of performance gains.
Great to see the 1A99 holding up so well on the 9850X3D! I'm seeing similar behavior on my end, I managed to stabilize my 9800X3D at -30 CO with this build. I'm also manually locking SOC/VDDIO at 1.25V like you, as the аuto settings are definitely a bit over-voltage. Even without a massive raw performance jump, the improved stability with tight timings and deeper undervolting makes this bios a clear winner over 1A95 for me. Cheers
Hello there.
Thank you!
You'll never get a changelog here on this channel, just like SVET doesn't get one either. However, even the official release changelogs are ridiculous and most often written uselessly and poorly.
Look, we all know official changelogs suck and MSI is lazy with descriptions, but let’s not take it out on Svet. He’s just passing these betas to us so we don't have to wait weeks for a fix. These builds are for enthusiasts anyway, the real 'changelog' is what we find out ourselves by testing. Just my two cents.
and where did I take it out on SVET ? I just stated what he said several times before he doesn't get it from the source, how is this considered "taking out" on anyone?
Fair enough, maybe I misread your tone. We’re definitely on the same page about MSI’s poor documentation, it’s frustrating for everyone. My point was just that I’m glad we have some way to get these fixes early, even if the paperwork is missing. No hard feelings!
Non taken I also like what SVET is doing.
I just installed A99 performance better than A95 not error 0d anymore, this morning I got odd thing cannot turn on pc with once push button to start pc, must push power button twice. Push power button first time not on, push second time the PC will boot up without any issue. The same thing happened with the previous A65. Does anyone know what's going on ?
That sounds like a classic cold boot issue. Since it happened on A65 too, your board is probably struggling with initial memory training or PSU power states. Try setting memory context restore and power down to enabled instead of auto, and maybe switch power supply idle control to typical current idle. It should help the board wake up on the first try
Ok thank you, I will try your suggestion to see if it boot up perfectly or not.
