Beta BIOS for MPG X870E CARBON WIFI
Beta BIOS/FW/Software
ADMIN
>>> E7E49AMSI.1A1E <<<
>>> E7E49AMSI.1A1H <<<
>>> E7E49AMSI.1A21 <<<
>>> E7E49AMSI.1A22 <<<
>>> E7E49AMSI.1A24 <<<
>>> E7E49AMSI.1A25 <<<
>>> E7E49AMSI.1A26 <<<
>>> E7E49AMSI.1A28 <<<
>>> E7E49AMSI.1A29 <<<
>>> E7E49AMSI.1A31 <<<
>>> E7E49AMSI.1A32 <<<
>>> E7E49AMSI.1A33 <<<
>>> E7E49AMSI.1A34 <<<
>>> E7E49AMSI.1A41 <<<
>>> E7E49AMSI.1A44 <<<
Notes:
  • * Unstable RAM OC
>>> E7E49AMSI.1A62 <<<
>>> E7E49AMSI.1A65 <<<
>>> E7E49AMSI.1A66 <<<
>>> E7E49AMSI.1A93 <<<
>>> E7E49AMSI.1A99 <<<
.rar SHA-256: 0da3ebedfa9e1f53f3e3aa320c1fd32f770cae0b32f112fe87750f1f88031487
BIOS SHA-256: 07a227bb302e9eac43bca0e18a43cfe58e043302eebfb13b08c7b8653a8ad636
>>> E7E49AMSI.1AA1 <<<
.rar SHA-256: cf63c3ad59580532257612b108db651ec3341a517c22efb20127dd44c94d8ae1
BIOS SHA-256: 4BD52D73DE3112768E2C6C62CA85C423F0963359A4C4B1CFCFEF1C04294DE1D2
AGESA version:
>>> E7E49AMSI.1A9B <<<
.rar SHA-256: 9eae3f5df43c2696e64ef329c6fddc45ba2e40ec0b529a9c451fa3871b077bff
BIOS SHA-256: 2B34A9B25DDEC186AC2272334DC2666C80082B143468A4D9D470BE88AB2C4CB4
AGESA version:
>>> E7E49AMSI.1AA2 <<<
.rar SHA-256: 3e1eec8ecdd717f7b694f7a82e704d4fb7ef54ad4f357fe5e28de6b9de422473
BIOS SHA-256: B1172777823B553168B6B1A14C57CAF7E7B48C259EBC43586B39C2A9BC4C8542
AGESA version:
Latest version: (from msi web page)
7E49v1AA3:
BIOS SHA-256: AF55A578CBDE8138906094F1CAD8C4C6A06639C4DAB23C0D7ACEA392326847AA
AGESA version:
>>> E7E49AMSI.1AA4 <<<
.rar SHA-256: 501a027d7cc8d1016f0164a0e7ec5a5f1cf39a32c13ad90af2c70e3dc90bfce2
BIOS SHA-256: 2A98DA827D82FF800397AF901680995D5481DC7DE8D62BAB6890DB9119C472F7
AGESA version:
7E49v1AA7:
BIOS SHA-256: 060DCBFB7B80454820B56418A55255BEF9E79686C6CF43D1522D015AA5B82CFE
AGESA version:
FYI:
With >>Forum UEFI Shell Flash & Patch Tool<<
you can copy the generated hash of the BIOS file quickly,
by loading the BIOS and click over BIOS-SHA256 on the bottom:
then in this topic you can do press CTRL+F in your web browser,
paste the contents to check if will match it.
Aside from this you can check AGESA version of the BIOS File,
and / or let the tool prepare the USB key for flashing
either by the tool by booting from USB key or by M-Flash.
While doing USB key preparation with the tool,
it will ensure the BIOS File's integrity on the USB key of both Checksum and SHA256.
This also will ensure your USB key used is not damaged or corrupted prior flashing
regardless of the flashing method.
_
Hi. I'd never owned an MSI motherboard before. I did have an ASRock X470 Taichi and an ASRock X670 Taichi. Both were extremely unstable, and their PCBs were poorly designed. They had screws for the NVMe drives, which broke very easily, and the debugging LED was hidden (unlike the X870E Carbon, where it's visible at the top). I chose MSI because, on several forums, many engineers told me they made the best motherboards—very well-built, stable, and reliable (obviously, everyone has their own opinion). I'm happy. I haven't had such a stable PC since the Taichi X470. I've had it for 10 months now. The problems I had with restarts, black screens, and shutdowns were due to my 7900 XTX. The PCI-E speed on the 7900 XTX was always 4.0 GHz... and with the 9070 XT, it remains at 5.0 GHz. Removing the NVMe SSDs and tinkering with it is so convenient, it's a real pleasure. They should take care of their customers, even when they release new motherboards.
The engineers aren’t wrong, and I give credit where it’s due MSI’s build quality is nearly top of the line. The problem, in my opinion, is QC too many boards are released with twitchy issues. Since MSI has adopted a policy of blaming customers and refusing RMAs whenever possible, they can’t collect boards or investigate problems, leaving them pretty much unaware of the issues. It feels like it’s all about profit, profit, and more profit refuse RMAs, blame the customer. The design and build are solid, as I said before, but support, QC, and RMA are practically nonexistent. And they’re not alone ASUS is even worse, the kings of unfriendly customer behavior and relations.
>>> E7E49AMSI.1A1E <<<
>>> E7E49AMSI.1A1H <<<
>>> E7E49AMSI.1A21 <<<
>>> E7E49AMSI.1A22 <<<
>>> E7E49AMSI.1A24 <<<
>>> E7E49AMSI.1A25 <<<
>>> E7E49AMSI.1A26 <<<
>>> E7E49AMSI.1A28 <<<
>>> E7E49AMSI.1A29 <<<
>>> E7E49AMSI.1A31 <<<
>>> E7E49AMSI.1A32 <<<
>>> E7E49AMSI.1A33 <<<
>>> E7E49AMSI.1A34 <<<
>>> E7E49AMSI.1A41 <<<
>>> E7E49AMSI.1A44 <<<
Notes:
  • * Unstable RAM OC
>>> E7E49AMSI.1A62 <<<
>>> E7E49AMSI.1A65 <<<
>>> E7E49AMSI.1A66 <<<
>>> E7E49AMSI.1A93 <<<
>>> E7E49AMSI.1A99 <<<
>>> E7E49AMSI.1AA1 <<<
AGESA ver:
SVET that pitcure isnt AGESA I think you uploaded the wrong image ;)
Upgraded to 1AA1 as well and everything is running perfectly so far. All my usual tuning settings got accepted right away-memory tweaks, voltages, and forced global c-states enabled.
The best part is that my fan curves actually stayed intact after the flash this time! Performance is exactly as expected on the 9800X3D. Big thanks to Svet for sharing it!
Hello guys,
I think I have a bios bug, I have MPG X870E CARBON WIFI , I use 9950x3d , 4090 with 4 x SN850X but PCI Express its stuck at Gen 4 x8, AMD 1.A64 bios
Hello guys,
Yes, perfectly normal, as you can’t run 4x Gen4x4 plus VGAx16 in this configuration. You can only run VGA x8 since one of the M.2 ports shares lanes with VGA namely M2_2. You can run 3x NVMe while keeping VGA x 16, but you still have to pay close attention to which NVMe ports you populate to avoid lane sharing.
No BIOS update will ever change that as it is hardware limitation of the chipset and board.
Check this link to see LANE configurations for Carbon Wifi to avoid lane sharing:
https://mobomaps.com/or
Don't tell me "no problems here" or "it's working great"—I've used BIOS versions a95, a99, and 1AA1, and I've consistently run into the 0D error.
BIOS versions a95, a99, and 1AA1 still trigger the 0D error, though it happens less frequently than before. Dealing with the 0D error today has been a real headache. I’m hoping the issue won't appear in AGESA version 1.3.0.1b.
well, that's you then, or maybe your Carbon WIF is a POTATO like many others unfortunately have, NOT a single twitch here works PERFECTLY in fact the best so far
