bios help
robert.h-15f402ef
hi all, iv had ny pc about 4/5 years now and have never ben able to get into bios... AMD A8-6600K APU with Radeon(tm) HD Graphics 3.90 GHz.
Everytime i access bios my screen goes big, and only shows settings, when ever i click on settings my pc freezes until i restart it. my pc can still boot up as normal but no access to bios
badboy2k
are you using a TV as a monitor as that is usually caused by that rather then a PC monitor?
Alan J T
🙈 🙉 Just 🐝 🤬😈
Go to monitor setting or tv setting and select scale to fit or stretch to fit or centre one should get it working correctly Also try AUTO on the Aspect Ratio
robert.h-15f402ef
I’m using a 43 inch tv, unfortunately no monitor around, I have tried this how ever it’s not to do with the scale of the tv as when I select on settings in bios the whole system just freezes until I reboot it
Alan J T
🙈 🙉 Just 🐝 🤬😈
This is the page it crashes on unfortunately
Looks bad can you try your Xbox HDMI cable see if that makes a difference just unplug Cable from back of Xbox and plug in to PC as you know that is fully working.
Was going to suggest to update the bios but you have the most up to date on all ready.
A cmos BIOS reset may help but not sure it would and I guessing you may have already tried that.
robert.h-15f402ef
I have tried multiple cables unfortunately, including the Xbox one even from both Xbox, they both work fine on them, even on the pc it works, I can boot into windows just as fine with them, but trying to enter the bios is a no go, I did a cmos reset and it’s still the same, and I’m not to sure if it is or not as iv never tried to update it and bought the pc about 4-5 years ago
badboy2k
Do you know anyone who could Borrow you a Actual PC Monitor to try on it?
Hardcore Games™
SECOND LIEUTENANT
If your rig is freezing in the BIOS it suggests you need a BIOS update.
dfspencer315bd02e5
Does anyone have the MSI E7693 aMS V1.4B8 MB? I'm trying to enable TPM so I can install Win11, when I go into BIOS, advanced, I do not have the security option, which is where I need to go to be able to enable TPM.
BaDboD
hmm.. bother.
STAFF SERGEANT
