Bluetooth LE Audio Driver??
itachimetal
there's anyone who could find the new LE Audio driver for RZ616 wifi/bluetooth card?
this new driver is to enable that new windows 11 Superwide Band 32khz audio for Bluetooth audio devices
i saw on other brand forum where they provided for the RZ738 (MT7925/MT7927) which is WIFI 7 and BT5.4.
[ random user with RZ738 from other brand ]
[ Mine MSI B650M GAMING PLUS WIFI with RZ616 ]
FYI:
BLE function is not available on AM5 platform due to lack support of AMD DSP (digital signal processing) feature.
AM5 supports DSP only on mobile product, but not desktop.
Looks like MSI got the BT driver version same as other brand which is 1.1038.0.440.
So I suppose you don't find anything regarding MT7922?
i found on the ms catalog update the version: 1.1043.0.554
but it seens still not working
i'm on the windows 11 25h2 build.
so sad that msi drivers is old and amd also dont care or provide driver ( they make partnership with mediatek! so they could provide driver by themselfs)
i think i should migrate to qualcomm chip (intel do not work on amd)
FYI:
i hope they release some update soon
i saw other ppl getting the the AudioLE working on b650 in motherboard from other brands
pairing with cpu ryzen's 7000s or 9000s
First of all 25h2 is a beta release and it states do not install it if you don't like troubleshooting windows. OBVIOUSLY you don't have the ability to troubleshoot it So why did you download it. It clearly states do not download unless you are Knowledgeable about troubleshooting.
25H2, no longer Beta. Has been released to the general public.
25h2 is not the requeriment / mandatory
the new protocol SWB (superwide band) is to enable the use headphone+mic without switching to mono channel
the requeriments is:
- A bluetooth LE Audio compatible and that have or implements the lc3 codec and tmap profile
- win11 24h2 (latest build/update at least).
the manufacturers of the BT device, motherboard or bluetooth adapter must release update to enable support
There's more, the function will not be made available in Windows settings unless an LE device has been connected to the Computers Bluetooth
So, the only way it may be selectable in settings is after one has connected a LE device to an AMD system
There may also be a problem with non-Intel Bluetooth devices working correctly
Links to back up your claims would be nice to see
