Bluetooth or WI-Fi Not working
After 2 weeks the bluetooth just disappeared on my pc and I,ve tried updating my drivers and I've tried going into the device manager and I've tried going into services and making bluetooth automatic but when i troubleshoot it it still says that there's no bluetooth capabilities...
Any help on the matter would be much appreciated
Bluetooth or WI-Fi not working try this
turn off PC and unplug PSU and wait 10 minutes or Hold down Power button on PC for 30 seconds, Plug back in and turn on PSU and boot Bluetooth or Wi-FI should now be back
Test Post Feb 20 2025. Test to see if I can post in forums as I am unable to update my profile. Please say hello if you can read this.
Ok post worked thanks.
May need to wait 24 hours before updating Profile if changes were made
I've wasted a lot of time dealing with this issue. My finding is that Mediatek RZ series wifi/bt combo adapters (like RZ608) typically supplied with AMD motherboard platforms either have a high defect rate or the driver/firmware is unpolished. The reason why removing power from the system for a few seconds works to make the device function again is because these devices run on standby +5V current over USB, which means under default BIOS settings the device will be on and stuck in its malfunctioning state even if the system is powered off. I have found no permanent fix. The RZ608 on my motherboard continues to crash frequently despite downloading the latest drivers from Mediatek themselves (not motherboard vendor), and it's not an OS issue. BT is just as dead under a Linux distro as in Windows. I'm just going to get an add-in card with an Intel chipset, and avoid buying any products with Mediatek radios in them in the future.
You can allways try different vendor Wifi/BT card from ebay and replace original. Intel BE200 NGW as example, have both latest Wifi 7 and BT 5.4, cost about 20-25 bucks.
U mnie na X870E Carbon wifi w pewnym momencie znikła karta sieciowa wifi, bluetooth zintegrowane w tym samym module działało bezproblemowo. W menedżerze urządzeń była widoczna z żółtym wykrzyknikiem i kodem błędu 10 nie można uruchomić urządzenia. Nie pomogła aktualizacja sterowników ani katy wifi ani sterowników chipsetu ani aktualizacja biosu z wersji 1A40 na o rok młodszy 1A95. Wrzuciłem problem do Ai i podpowiedziała mi że jednemu użytkownikowi pomogło wyłączenie jednej z 2 kart sieciowych przewodowych (płyta ma 2 karty 2,5 i 5 gigabit) i to pomogło. Po wyłączeniu obojętnie której z tych kart wifi wraca do działania a ponieważ jednocześnie nie korzystam z dwóch kart przewodowych to takie rozwiązanie mi odpowiada. Dodam tylko iż mam rozbudowaną konfigurację Kartę RTXz serii 5000 korzystającą z PCI-E 5 główny dysk M2 na PCI-E 5 2 dyski M2 PCI-E 4, 4 dyski HDD i dodatkowy kontroler SATA do napędu DVD według Ai to to wygląda na konflikt zasobów PCIe być może wykorzystałem wszystkie dostępne linie i to jest tego efekt.
