Bluetooth Problems on Pro Z690-A
erman.akkay159c02e9
I have the Pro Z690-A Wifi DDR4 which I bought 2 months ago. I'm using Windows 10.
Bluetooth was working perfectly until last week. All of a sudden my keyboard started to press the letters many times instead of one, after sometimes totally disconnecting. I thought it was about the keyboard, so charged it's battery, tried it with another computer. Works without any problems.
I tried to connect my Xbox Controller, cannot. The device can be found in the Bluetooth search but cannot be added. It keeps saying "try connecting your device again"
I updated the BIOS once I bought the motherboard. I checked and didn't see a new firmware out sinde then.
The Windows is up to date.
Installed the Intel Driver Support Asistant and updated the Bluetooth driver, no change.
Tried an old Blutooth USB dongle I had at home, everything works perfectly with that.
Before formatting the PC and reinstalling Windows or sending the motherboard to technical service wanted to write here if there's anything I can be missing.
Edit: Nevermind, found the solution just after posting here. To install a new part I removed the antennas and forgot to put them back, stupid me...
Pro
Yeah, the antennas are crucial for both the WLAN and the BT.
Alan J T
