I bought this used GPU and installed it today. I used the adapter that came with the card, however, I'm somewhat concerned that the connector that goes on the GPU lacks four "sensing" pins that are on the card's connector and maybe why the GPU has no sign of life.
When I powered up the system, the GPU fans do not turn and there are no lights. Aren't these things supposed to light up like a Christmas tree?
There is no display on any of my connected monitors either.
Do I need the special cable that has 24 pins plus 4 pins on the side to make this card power up? The seller included a cable that has just the 24 pins on one end and three 8-pin cables which I connected to the PSU's VGA AUX power connectors. He said he repasted the heatsinks as well.
There is some visible rust corrosion on the backplate screws and corrosion on the heat sink assembly and backplane, so I'm not too confident that the card is functional, all though the seller included a Furmark screen shot in the sale listing, showing the card performing well.
System configuration:
Supermicro X10DRi motherboard, BIOS latest at v. 3.4a
128GB RAM
Dual Xeon E5-2667 v3 CPUs
All drives SSDs
Reason for the GPU upgrade is my GTX1080Ti was maxxed out at 99% during playback in DaVinci Resolve Studio 20 while main CPU usage was under 5%. GPU was a huge bottleneck. Need Tensor cores to run Resolve's Neural Engine.
How do I get this card to power up? Or how do I know if it's defective?
128GB RAM
All drives SSDs
