BUG Bug Report / Feedback – MAG Z890 TOMAHAWK WIFI (Original Version) – DC Fan Control Initialization Issue After Complete AC Power Loss
Describe in details the bug you found
fabus23
Hello MSI Team,
I would like to report a minor but reproducible fan control issue observed on my MSI MAG Z890 TOMAHAWK WIFI (original version, NOT the MAG Z890 TOMAHAWK WIFI II).
This is not an RMA or repair request. My computer works properly, and I have found a simple workaround. I am sharing these findings purely as technical feedback, in case they are useful to MSI's BIOS development team.
1. System Configuration​
  • Motherboard: MSI MAG Z890 TOMAHAWK WIFI (original version, not WiFi II)
  • BIOS: Latest available version installed (exact version to be added)
  • Graphics card: ASUS TUF Gaming GeForce RTX 5080
  • Memory: 64 GB G.Skill DDR5-6000 CL30
  • CPU cooling: be quiet! Silent Loop 2 360 mm AIO liquid cooler
  • Case: Equipped with seven fans
  • Affected fans: 3-pin DC-controlled case fans connected to SYS_FAN2, SYS_FAN4 and SYS_FAN5
The AIO pump and radiator fans are controlled separately from the affected case fans.
2. BIOS Fan Settings​
The three affected SYS_FAN headers use the following settings:
  • Fan Control Mode: DC
  • Smart Fan Mode: Enabled
  • Temperature Source: MOS
The same custom fan curve is applied to all three headers:
MOS TemperatureDC Voltage
35°C0.00 V
45°C6.00 V
67°C7.20 V
85°C12.00 V
The purpose of this configuration is to keep the case fans stopped at low temperatures for quieter operation and automatically start them when cooling is needed.
I also tested CPU Core and System as temperature sources. The issue was present with those configurations as well.
3. Steps to Reproduce​
  1. Shut down Windows normally.
  2. Switch off the power supply using the physical 0/I switch on the back of the PSU.
  3. Switch the PSU back on.
  4. Start the computer normally.
Observed behavior:
On the first boot after complete AC power loss, the affected case fans spin continuously at low speed, even when the selected temperature is low enough that the configured fan curve should keep them stopped.
This behavior continues after Windows has fully loaded.
Expected behavior:
The fans should remain stopped at low temperatures and follow the configured Smart Fan curve, including the 0 V fan-stop setting.
4. Important Finding: A Simple Restart Fixes the Issue​
If I restart Windows normally, without switching off the power supply and without entering the BIOS, the fans stop correctly and begin following the configured Smart Fan curve.
I also found that simply entering the BIOS restores normal fan behavior, without changing or saving any settings.
In other words:
Startup ScenarioFan Behavior
First boot after complete AC power lossFans keep spinning slowly
Windows fully loaded after that first bootFans continue spinning slowly
Normal Windows restart without AC power lossFans stop correctly and follow the curve
Entering the BIOS without changing settingsNormal fan behavior is restored
This suggests that the issue may be related to fan controller initialization during the first boot after AC power is restored.
5. Tests Already Performed​
I have performed the following checks:
  • Confirmed that the affected 3-pin fans are configured in DC mode.
  • Confirmed that Smart Fan Mode is enabled.
  • Tested CPU Core, System and MOS temperature sources.
  • Tested ErP Ready enabled and disabled, with no improvement.
  • Tested Fast Boot enabled and disabled, with no improvement.
  • MSI Fast Boot is disabled.
  • Verified the behavior after complete AC power loss.
  • Verified that a normal Windows restart restores proper fan operation.
  • Verified fan operation under load using OCCT.
During OCCT testing, the fans started correctly as the MOS temperature increased, approximately around 40–45°C.
With the current MOS-based fan curve, the CPU temperature was approximately 74°C during a test load, and the case fans responded correctly.
This confirms that the fans and their custom curve can operate as intended once the controller has been initialized properly.
No Clear CMOS has been performed since the BIOS update.
6. Possible Firmware Initialization Issue​
Based on these observations, I suspect a possible BIOS or embedded fan controller initialization issue following a complete AC power loss.
The Smart Fan settings appear to work correctly after a warm restart, but the fan-stop command may not be applied correctly during the first cold boot after AC power is restored.
I cannot confirm the root cause, but the behavior is reproducible.
7. Purpose of This Report​
I am not requesting an RMA, a replacement motherboard or immediate troubleshooting assistance.
I simply wanted to share this observation with MSI so that the BIOS development team can investigate it if appropriate.
If this behavior is already known, or if a future BIOS update addresses it, that would be useful information.
I can provide BIOS screenshots and additional test results if required.
Thank you for your time and for considering this technical feedback.
Best regards
great observation, this will need msi to help confirm the situation and check for possible solution..
btw, as the 3pin system is bit old, if you have chance to try the 4 pin system fan, you could check to confirm
To confirm the problem, you can try set first point to 60 degree to rule out the possibility that the MOS temperature exceeds 35 degree and causes the fan to spin slowly.
I understand you say the temperature is low enough but just wanna rule out any possibility since you didn't mention how low the MOS temperature was it.
