My cpu fan has max 2000rpm.
Testing with MSI Center manual fan control, there is a 7 seconds delay before the fan will even spin up.
and when it starts to spin up, the fan takes 20 seconds to reach max rpm, even as I call for 100% voltage.
This is the same behavior when the fan is in auto mode, when there is a cpu load.
When I go to manual fan control tab, the fan should spin up right way. It does not.
There has to be a way to hack the bios to deliver instant voltage to the fans.
When cpu is put under 100% load, look at how long it takes to spin from 800rpm to 2000rpm, which is lowest speed to max speed....
Every step up is 1 second ! It takes about 16 seconds to spin up the fan.
The bios is set to level up the fan speed with 0.1s delay, but this is a whole 1 second delay !
The bios fan control delay needs to be fixed.
Watch this video I recorded. Notice the RPM and the amount of time that passes. ....
