Buying a chronically defective products
4must157102d9
I did not play games for 3 months on the notebook I bought 4 months ago. I didn't see any problems as I didn't play games, except for the bad quality screen frame and mouse pad. When I touch the screen bezel and mouse pad, it makes a sound and there are gaps. A lot of problems have come to my attention since I started playing games. Chronic WIFI disconnection and high temperature 90-92 even in games that require the lowest system.
I solved the WIFI disconnection by changing the 2.4 ghz and 5 ghz bandswitch from automatic to 20 mhz, but the high temperature still persists.
I contacted MSI support and tried every possible solution but could not find a solution to the temperature problem. When the temperature is 90 degrees, the game freezes and fps drops. Also, as far as I know, the 90 degree temperature damages the hardware and I think the maximum lifetime of this notebook is 1 year.
And most of the drivers on the product site are out of date and some are not compatible, for example: the video card.
I don't know what should I do now? Should I send this chronically defective notebook to the service? Even though there is no mistake from me. Or should I break it and throw my garbage? I just feel sad that I could buy better one with 1000 dollars.
What product are you referring to?
GF63 THIN 9SCX 00JP NOTEBOOK
I made a video to explain the problems better.
MSI SUPPORT says 90-92 GPU temperature is normal for gaming notebooks.
I have watched videos of MSI's notebooks with the same features, their temperature is maximum 80-83 and their performance is better than my notebook at high settings. I'm leaving a few videos here.
(90-92 temperature is considered normal for gaming laptop since your laptop is with powerful 9 th generation Intel CPU. And when gaming, with such usage, it's easier for the laptop to generate heat)
3DMARK FIRE STRIKE test. https://www.3dmark.com/3dm/50397011?
You should update the software on that computer by going to intel directly for wifi & chipset driver updates and nvidia for graphics drivers. That laptop is entry level and isnt designed to be pushed too hard. Also i would check you have the latest bios and embedded controller(EC) firmware installed. The cooling on that laptop isnt the best looking at the reviews, you can get laptop cooling pads that might help.
first video ,,your system ??
gpu limit "temperature reason",,1400mhz is base + boost3 !1650mhz" example
,,your gpu 990mhz only + "on graph ,.,all time drops down in millisecond" must use graph
cpu 25w is normal for this notebooks "one fan"
wifi ? imposible repair or use recommended setting intel web + last drivers
best msi support DIRECT and need better EC FW ,,think
battery master must set to 100./. recharge - best stability/performance
GF or similar 8GB ram + only hdd -all time page file ---hdd lag --fps drops
LOG guide
riva server ,,run first "must exist RTSS tab in hwinfo sensor" FPS
riva server
hwinfo
https://www.hwinfo.com/hwinfo LOG guide
LOG guide
LogViewer "compare FPS VS DROPS"
tool for LOG check
alternative ,,OSD + HWINFO IN BACKGROUND "or HWINFO + graphs -background"
OSD - RIVA SERVER + Afterburner or RIVA + HWINFO
"need setup in app afterburner -monitoring tab /or hwinfo -rstt tab" + must run riva server \ enable OSD in RIVA app
,.all info realtime --stress MSI kombustor "faster setup" possible load gpu "core/vram/cpu cores/package"
or in your GAMES -find problem for repair
hwinfo -my screen -all info from CPU LIMITS
gpu - check drops in 3d load "graph best"
FPS - from hwinfo or afterburner + RIVA server "graph best" in games check situation
other limits -temperatures 90C up / power limits / -- CLOCK / RATIOS "small drops -normal"
down to LFM "minimal state" -problem "best LOG compare FPS VS DROPS"
translation ,,sorry
GPU vcore limit
https://forum-en.msi.com/index.php?threads/gtx-1050-ti-laptop-90-while-gaming-cooler-boost-activated.337760/
