Call of Duty BO7 attestation fails BAD_KEYSET on MSI MPG X870E EDGE TI WIFI, despite successful AIK enrollmen
mctrafik+msi
System
- Motherboard: MSI MPG X870E EDGE TI WIFI (MS-7E59), board version 1.0
- BIOS: 1.A93, dated September 2, 2026 (latest available to me)
- CPU: AMD Ryzen 9 9900X
- OS: Windows 11 Pro 25H2, build 26200
- AMD fTPM: TPM 2.0, manufacturer firmware 6.33.0.6
What passes
- The Call of Duty Secure Attestation Wizard reports TPM 2.0 present and Secure Boot enabled.
- Its TCG log and EFI measurement checks pass; AMDFW_NEEDS_UPDATE is false.
- Windows reports VBS, HVCI, and IOMMU running/enabled.
- System log contains TPM-WMI Event ID 1808: “This device has updated Secure Boot CA/keys.” UEFICA2023Status is Updated.
What fails
- The wizard’s only failed diagnostic check is BAD_KEYSET (value: true, expected false). Generating a new key does not make it pass.
- Running certreq.exe -enrollaik -f -q -machine -config "" ActivisionAIK as Administrator succeeds: EnrollStatus(1): Enrolled, HTTP 200, exit 0.
- I deleted only the existing ActivisionAIK key container, confirmed its removal, successfully re-enrolled it, and reran the wizard. BAD_KEYSET still failed. I have not cleared the TPM or reset Secure Boot keys.
- The wizard’s own log says its elevated enrollaik.exe exits 0, but the subsequent check still fails.
Question for MSI: Is there a known MS-7E59 / BIOS 1.A93 / AMD fTPM 6.33.0.6 issue that allows Microsoft AIK enrollment to succeed but prevents CoD’s attestation/key-use check? Is there an MSI firmware/PSP update or a specific TPM attestation test you recommend before clearing the TPM?
Thanks, but I needed a public forum. For my case, as expected the issue was in Call of Duty code. It asked from admin privileges but didn't use them to read the ActivisionAIK key and that's why failed. Of course their incompetent engineers make this condition throw a bad key warning. And their incompetent support says that I need to contact MSI.
