can a ryzen 3 4100 be installed on a a320m pro m2 board?
inf15b402ea
Can a ryzen 3 4100 be installed on an a320m pro m2 board? It doesn't appear in the list of supported processors and I would like to know if it is possible to install and install that processor and if it is necessary to update the bios or not It is necessary, do I need it to have a different processor or could I do it with the ryzen 3 4100 installed if necessary?
¿Se puede instalar un ryzen 3 4100 en una placa a320m pro m2?, es que en la lista de procesadore soportados no aparecy me gustaria saber si es posible instalar e instalar e instalar ese procesador y si para ello hay que actualizar la bios o no es necesario, ¿necesito que tenga un procesador distinto o podria hacelo con el ryzen 3 4100 instalado en caso necesario?
badboy2k
Please only post on here in English as this is the Global English Forum. >>Please read and comply with the Forum Rules.<<
Please feel Free to use a Online Translation Website to convert Your Language to English.
and the Answer is no it does not support it as the microcode of the BIOS has no support to even know what they are.
inf15b402ea
badboy2k
the Answer is No it does not support it as the microcode of the BIOS has no support to even know what they are.
it only supports Ryzen 1000, Ryzen 2000 and Ryzen 3000 CPU's
inf15b402ea
sorry for the inconvenience, but it is that on the amd page it indicates that it is 3rd generation and on the board it says that I support up to the 3rd generation, that is why I asked, I also have several B450M pro m2 and a B550M pro, one of the reasons for choosing that process has been to support w11, as there are others that do not indicate that they are compatible with windows 11.
Thank you
Icono de Validado por la comunidad
darkhawk
A Ryzen 3 4100 is technically a 4th gen Ryzen....
The Ryzen 3 4100 is supported on the B450M Pro M2 as well as the B550M Pro board.
It is NOT supported on the A320M Pro M2 board though, as best as I can tell.
