Can I use onboard USB3 hub (JUSB2 socket) as USB2 on P67A-C45..?
ponx
I have a CM-Scout case with 4 USB2 ports on the top/front.  I can plug one pair of these ports into the JUSB1 socket on the C45 mobo, but unfortunately, JUSB2 is USB3 and has more pins.  Therefore, I am left with two unconnected ports on the front of my case...  :cry:
In the mobo manual it does mention something about a USB3-to-USB2 converter thingy, but only for the other motherboards the manual covers, not the C45.
Does anyone have any insight as to whether I can use my remaining two external USB2 ports in the JUSB2 socket on the C45 mobo........???
ponx
I have a coolermaster cm 690 case with the 2 usb connectors on top with a c43 mb and i connected the usb adaptor to the usb3 pin out which then connected with the coolmaster usb2 connectors,didn't you get the adapter plug that goes into the usb3 socket?
