Can't find the right battery suitable for my Prestige 14 A11SC
vivimm77915c702e7
Hello everyone. My laptop(Msi Prestige 14 A11SC-081CZ-GG71195U32GXXDX11SA) battery is broken, and I need a new one. Could you tell me the exact model and type of battery that is compatible with my laptop? I can't check my old (broken) battery because I immediately threw it away (yes, I'm stupid). I didn't know finding a suitable battery would be so difficult. I just need to know the exact model so I can buy it, and I'll install it myself. Please anyone provide me with information so I can find a battery that will work exactly with my laptop. I really like the laptop itself, and it works great off the mains without a battery inside, but I still need one for mobility and using the laptop on the road. I would be very grateful for your help.I tried to find information about the model and type of the correct battery, but I couldn't find a specific battery that I was confident in. Will appreciate any help. I am sending you a photo of the back panel of my laptop with the model and serial number, as well as a photo of the place where the battery was (unfortunately I threw it away after it broke).
Just did a quick search for "MSI Prestige 14 battery". Looks like they use the same battery across all versions of the Prestige 14, so if the replacement says Prestige 14 in the name you should be all right.
