lengochiep19915d102ea
- Sep 18, 2022
MSI Center 1.0.61.0 is still not working. Please check the attachment file
MSI Center needs to check if the board's compatible by the baseboard information. are you still using hackintosh? changing the product name might affect hackintosh support.Maybe the information was changed when I tried to hackintosh my computer. Is this really causing MSI Center problems? How can I change the product name? thanks
Yep that be the problem is not very common but appears when the base info has been modified for a some what legit Hackintosh like you have done, or the other is to bypass anti cheat lockout on a hardware level.Maybe the information was changed when I tried to hackintosh my computer. Is this really causing MSI Center problems? How can I change the product name? thanks
