CD-RW problem
S
slavke
Guest
ok I have dvd drive and MSI 40x12x48 CD-RW and it works propertly with "Nero burning rom" but on some other burning programs like easy CD creator shows this message once I run it: "no compatible Recorder drives have been found in this computer."
I hate nero so I want to use some other burning programs.
Please help me!!!
Hi!
Are you sure that all traces of Nero have been removed from your computer? It is known that Easy CD Creator and Nero (and other burning programs) do not mix together very well. It could be the origin of your problems ...
Hope this helps,
Hans
You could also find that easy CD creater uses ASPI codes which the MSI burner may not use.
Nero supports burners without ASPI.
Could try Ferio??
