CDRW problems!
edyros
FIRST LIEUTENANT
Hi every one:
Hope you guys are OK when reading these few lines.
The reason I'm posting this message is because I have a problem with a new Lite On 52X/32X/52X CD RW drive I bought yesterday.
It looks like (sometimes) when you insert a data disc it doesn't recognize it and apparently it looks like there's no CD on it. I checked the IDE cables and change them but still having the same problems. Both the CD-RW and DVD drive are using the same secondary IDE channel ( I set the CD-RW as Master and the DVD drive as slave) and the hard drive is uing the primary channel (Master) (lol).
When a try to read a disc it starts reading but then suddenly it stops. When I preview the Warcraft III intro it just skips and it freezes. The DVD drive is working fine so it can't be the IDE cables. Both drives has DMA on.
I disabled the DVD drive and the CD-RW still not working!
I tryed to make a clean Windows XP installation ONLY using the CD-RW drive but it doesn't read the disc and it skips the boot sequence.
What can I do? ?(
My System:
KT4-Ultra S-R
Athlon XP 2700+ (fsb set to 166Mhz)
512 MB 333 MHZ Kingston Value Ram
80 Gig Maxtor (7200 RPM, UDMA 133)
LiteON CD-RW drive(52X-32X-52X)
LiteOn DVD drive (16X DVD/48X CD)
Omega 450 Watt PSU (3.3v->18A//5v->50A//12v->24A)
Toenne
LIEUTENANT COLONEL
Tested the CDRW in another PC? Maybe it's damaged.
edyros
FIRST LIEUTENANT
The damn thing is damage, what a bad luck of mine.
Next time I'll be more conscious when purchasing CD-RW drives (I'll test them at the retail store). :D
Thanks for your help anyway.
