- Sep 11, 2020
MSI have released a Patched BIOS for all their AM4 Motherboards, this is to remedy the COD/BF6 Game TPM error message.
Please keep an eye on the MSI web page of your motherboard for the BIOS updates.
Before you apply the BIOS Update, you will need to disable TPM in the BIOS to prevent problems with Windows Hello and Windows Activation errors.
Known AMD Limitation
- AMD does not support Ryzen 1000, 2000 TPM update
- AMD B550, A520 + Picasso will not work with TPM-B due to AMD limitation
- Turn off/backup/suspend bitlocker before BIOS flash (if you use the feature)
- Disable TPM in BIOS before BIOS flash
BIOS are available here
https://sites.google.com/view/msi-bios-update/menu/motherboard
These BIOS are coming straight from MSI, but if you have any concern, wait for official website upload version.
Update BIOS at your own discretion.
BIOS updates for 300, 400 and 500 Series Chipsets on the Support Site will contain TPM Patch 3.94.2.5 when available to download
Check Bios Notes to verify
