Cold Boot Issue / Hangs on VGA LED – Compatibility Bug between MSI PRO Z690-A DDR4 and Radeon RX 9070 XT with 4K DisplayPort Monitor
petr.kerek
**System Configuration (Verified via CPU-Z & AMD Adrenalin):**
* **Motherboard:** MSI PRO Z690-A DDR4 (MS-7D25), Rev: 1.0, Chipset Rev: 02, Southbridge Rev: 11
* **BIOS Version:** 1.O0 (Letter 'O' followed by number '0', Date: 08/20/2026), Brand: American Megatrends International LLC. (Fast Boot: Disabled)
* **CPU:** 12th Gen Intel® Core™ i7-12700KF, Alder Lake, Revision: C0, Socket 1700 LGA (No integrated graphics)
* **CPU Cooler:** be quiet! Shadow Rock 3 White (190W TDP)
* **Memory:** 32 GBytes DDR4 (Dual Channel, 2 x 64-bit), DRAM Frequency: 1795.6 MHz (DDR4-3600 effective), Timings: CL16.0-19-19-39, tRC 58, CR 2T
* **GPU Hardware Details:**
* **Model:** Sapphire Technology Limited - AMD Radeon RX 9070 XT (Revision: C0)
* **VRAM Size:** 16304 MB GDDR6 (Vendor: Samsung, Memory Clock: 2518 MHz, 20.14 Gbps, 644 GByte/s Bandwidth)
* **Core Clock:** 2520 MHz
* **GPU VBIOS Part Number:** 113-1E4893U-N8K
* **GPU VBIOS Version:** 023.008.000.068 (Date: 2025/04/02 03:52)
* **Device ID / Revision ID:** 7550 / C0
* **Vendor ID / SubSystem ID:** 1002 / E489
* **SubSystem Vendor ID:** 1DA2
* **Bus Type / Current Settings:** PCI Express 5.0 x16
* **Software & Driver Details:**
* **Driver Version:** 26.10.41.01-260811a-203304C-AMD-Software-Adrenalin-Edition
* **AMD Windows Driver Version:** 32.0.31041.1004
* **UI Version:** 2026.0811.2128.2099
* **OS:** Windows 11 Professional (64-bit), Version 26H2
* **PSU:** Zalman 1000W Modular (Connected via independent PCIe power cables directly from the PSU to the Sapphire adapter)
* **Monitors:**
* ASUS VG289 (4K, 60Hz, Connected via DisplayPort, Windows HDR enabled)
* AOC 24G4HA (FHD, 200Hz, Connected via DisplayPort)
**Description of the Bug:**
The system fails to complete POST during a cold boot and hangs indefinitely with a solid **white VGA LED** illuminated on the motherboard. This issue occurs exclusively when the 4K ASUS VG289 monitor is connected via DisplayPort and is currently in standby/sleep mode.
**Verified Reproducibility & Workarounds:**
1. **Successful Boot Workaround:** If the ASUS VG289 monitor is manually woken up or power-cycled via its physical power button immediately before turning on the PC, the system passes POST instantly and boots into the OS without any issues.
2. **Single Monitor Test:** If the ASUS VG289 monitor is completely powered off or disconnected from the GPU, the system boots normally every time using only the secondary AOC monitor must be manually wake up right before PC Power button is pressed.
3. **BIOS Troubleshooting Performed:**
* Manually forcing the PCIe link speed for the primary slot (PCI_E1 Max Link Speed) to Gen 3, Gen 4, or Gen 5 (PCIe 5.0 32.0 GT/s is natively supported) does not resolve the behavior.
* Disabling the "VGA Detection" parameter in the BIOS allows the motherboard to bypass the POST hang, but results in a black screen as the GPU fails to initialize properly, requiring a physical Clear CMOS reset via the jumper.
4. **Cables and Hardware:** The issue persists after replacing the DisplayPort cables with brand new, certified high-bandwidth cables and after replacing the secondary monitor. All hardware components operate perfectly stable once the system successfully reaches the OS.
**Conclusion:**
There is a distinct timing/handshake bug during the motherboard's POST sequence when initializing a modern RDNA 4 GPU (Radeon RX 9070 XT, VBIOS: 023.008.000.068) combined with a 4K monitor in standby mode over DisplayPort. The motherboard cuts the initialization window too short, flags a VGA error, and halts the boot process.
Could someone help me please with that issue :-(
Just wondering why do you think it's a BIOS issue rather than the monitor? Especially when you say other monitor works.
Becaus with different graphics card it is working fine ano when i connect botu monitors to laptop it works ok too. It looks likes GPU And MB kompatibility or BIOS bug.
Actually, I just did further testing today and proved it is definitely not a monitor defect.
I disconnected the new AOC monitor completely, left only the ASUS monitor connected, and made sure it was powered on and actively scanning for a signal on the DisplayPort. The PC booted fine after several attempts.
It doesn't matter which monitor I use. The issue is purely about the motherboard's POST sequence timing. If a monitor is in standby or if the GPU has to poll multiple DisplayPort connections during a cold boot, the MSI motherboard cuts the handshake window too short, flags the white VGA LED, and freezes. If only one monitor is actively scanning and responds instantly, it works.
This is 100% a motherboard initialization/timeout issue with the new RDNA 4 GPU architecture, not a faulty monitor.
Make sure any Fast Boot settings are disabled in the BIOS, this causes some hardware not to be initialized during the boot sequence.
If I recall, the AMD Sapphire went to the new 2.1b HDMI and 2.1a DisplayPort. Make sure you have compatible 2.1a/b cables or better
From Memory testing, using a previous-generation GPU that does not use the new Output formats is not going to give matching results, as most older GPUs use 2.1 or 1.4 output ports
MSI Fast Boot and also standard fast boot is disabled. I'm using AlzaPower AluCore DisplayPort 1.4 8K 3m (marked as certified) for both monitors. Just additional information:
PC is connected to both monitors via DP cables above. Both monitors are also connected to Notebook via HDMI (one directly to 4k monitor) and 2nd via old iTech USB-C port replicator. When I disconnected laptop from both monitors the PC started well but it was approx. 6th attempts as every day. I will try it later today and will see whether it is caused by multiple inputs plugged to monitors, even laptop was off (no sleep, no hybernated, regular shutdown). It always starts after some poweroff/on attempts.
Thank you everyone for the insights!
The issue has been successfully resolved, and it was not a defect in the motherboard, BIOS, or the monitors.
The entire cold boot hang (white VGA LED) was caused by an electrical/timing conflict on the GPU power supply side. The system was previously using an older 1000W PSU with a 3x 8-pin to 12VHPWR adapter split across three independent PCIe rails. During a cold boot, the modular rails of the PSU were likely initializing with a delay/asynchrony. The GPU power management sensors (Sense pins) on the Sapphire Radeon RX 9070 XT Nitro+ detected this unsymmetrical voltage rise and immediately blocked GPU initialization, causing the MSI motherboard to halt the POST sequence.
The Solution:
I replaced the power supply with a native ATX 3.1 compliant be quiet! Dark Power 14 850W (80 PLUS Titanium) and connected the GPU using a single, native direct 12VHPWR / 12V-2x6 cable. It merge the internal rails into a Single-Rail configuration to ensures completely synchronous power delivery in the exact same time.
With the native ATX 3.1 power supply, the system now passes POST instantly and cold boots perfectly fine every single time, even with multiple 4K and high-refresh monitors left in deep sleep mode.
