Compatability Issues - MSI Pro B660M-A DDR4 with XFX AMD Radeon 7700xt and 7900xt
lamatis2156b02d8
Hi yall,
Just looking for some help with an issue I've come up against. Here is the rig I'm currently working with for reference:
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler
Motherboard: MSI PRO B760M-A WIFI DDR4 Micro ATX LGA1700 Motherboard
Memory: Klevv BOLT X 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card
Case: NZXT H510 Flow ATX Mid Tower Case
Power Supply: EVGA SuperNOVA 1000 GT 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
Monitor: Acer VG272 LVbmiipx 27.0" 1920 x 1080 144 Hz Monitor
Monitor: AOC CU34G2XP/BK 34.0" 3440 x 1440 180 Hz Curved Monitor
So the issue coming up is I decided to spring after a XFX QICK 319 Radeon 7700 XT. Picked it up, installed it and no display, just the white VGA light on the MOBO came up. Did about every step of troubleshooting I could find (Changed out the PSU cables incase they were broke, went to the lower PCiE slot, Updated to latest BIOS, tried all the DP outputs to get a reading) and nothing fixed the issue. Every website I found said my MOBO should be compatible with the GPU, except the MSI website. So I decided to jump up to a MERC 310 7900 xt, and still at the same issue. Is there something I am missing that is making these incompatible? Do I need to revert the BIOS to an older version? Any help would be appreciated! (If anything I got the card today, so I can take it back if it just is not compatible). Thank you! :3
