chrisgulfne15bc02e6
- Mar 12, 2023
So I am nearly finished building a gaming PC for my son. Just waiting on a couple things. Can't seem to figure out how to connect the CoreLiquid K360 to the extra Male 3 Pin Connectors on the RGB Hub that comes on the Velox 100R. Of which there are 4 each that have rubber covers on them to protect them if not used. As well as 1 Male 3 Pin that comes off the RGB Hub itself. If I disconnect the 3-1 splitter that comes with the K360, it doesn't work because the male to female isn't compatible. I don't remember exactly but the jist of it is when comparing the female ends, 1 set is recessed farther back in the connector so when you try to plug one of the extra male 3 pins off the RGB Hub, they barely even touch. My reason for wanting to do this is so the K360's 3 RGB fans would match the rest of the Velox 100R's pre installed 4 RGB fans and function with the mystic light button on top the case. Any ideas ? Thanks for any help.
