I'm not really clear on the purpose of the M-connector kit. Is it better to plug the leads from the front panel into the M-connector and then plug the M-connector into the Mainboard, or can you just plug the leads directly into the Mainboard? I'm also confused because I don't get the instructions in the M-connector kit vs. the user manual.
I have a Coolermaster HAF922 which has the following front panel leads:
Power Switch
Power LED
HDD LED
Reset Switch
Should all of these be plugged into JFP1 or should everything but Power LED be plugged into JFP1 and the Power LED lead be plugged into JFP2?
Also, my leads aren't labeled + and -. Instead they are labeled with a triangle on one pin and G on the other. I assume that the triangle is + and the G is -?
Thanks for any advice you can offer!
Power Switch
Power LED
HDD LED
Reset Switch
