Constant noise from monitor when plugged in
I have an MSI MAG 271QPX and I ran into a lot of issues with it as explained in the earlier post.
There is one more which is kinda unrelated to all of those. The monitor emits a constant hum when plugged in.
It doesn't need to be turned on at all, just plugged into the outlet.
Is this a cause for concern? What does it mean?
Attaching the audio file. The wind like noise is the background noise of the room, the higher pitched pulsing noise is the monitor.
  • Sound.zip
Hi there,
I bough a new one and it came yesterday I have same "issue" (?). I thing it is just normal I saw on Reddit that msi mag series just have coil whine in standby. In my case it is really quiet that I can't even record this. If in your case the sound it is so loud that you can hear it even while working or chilling I think you should contact support 😄
