Good evening gents
I have 2x OCZ vertex 30gb raid-0 in my system and my raid array fails every 1-2 months.. im getting a little bit tired of recovering backups so im trying to find the source of the problem.
I have a MSI Eclipse SLI motherboard with the buggy NB which sometimes (not often) goes up to 95 degrees (most of the time its around 85 degrees). I already started a topic on the OCZ forums aswell and they say it could be the NB/SB that messes up my raid all the time.
I have 2 Samsung Spinpoints running in raid-0 wihtout any problems. In my opinion it couldn't be the NB/SB cause once every 1-2 months doesnt seem alot for the NB/SB to be the problem, i think it would occur alot more times if it really was the NB/SB. Putting new cooling on the NB/SB would be my extreme solution cause i have my CPU water cooled and it would take me sometime to take the mobo out again and trying to fix the problem.
I have my i7 920 running @ 4Ghz 24/2 at max load 60 degrees and is Linx stable (Ran it for multiple hours)
Do you guys think that the NB/SB is the problem or do you have any suggestions?
Ps. i have no problems with my PC without those SSD's.
Thanks in advance
Thanks in advance
