Control Center useage freezes machine
roncri
I've got a P67A-GD65 (B3) with a i7-2600K, 16GB RAM, GTX 560 Video Card and a SSD as my primary drive.  I'm running Windows 7 (x64). Control Center version is 2.1.012.  I went into the UEFI and made sure all settings are default.
I can launch CC fine but if I click on any of the profiles "Cooling", "Default", "Cinema" or "Game".  My system locks up.  Can't even Ctrl Alt Delete.  I have to hit the reset button on my case.
Outside of that, everything runs fine.  I've used the OC Genie button on the motherboard and it took her to 4.2Ghz, ran smooth as silk and temps never broke 60C.
Thoughts?
-Ron
I have the same issue, it's something with CC but MSI has been of little or no help regarding the issue. There have been a few other posts about this but seem to have disappeared. Most of the replies on them were to simply uninstall CC and do all overclocking from BIOS. I noticed on my P55-GD65 that these profiles adjusted voltages and fan speeds and a couple other things and I guess they just don't like SB. Hopefully MSI will acknowledge this issue before too long and get it fixed, until then I would try to avoid clicking them.
You can save your own settings and use those. I used it to OC my processor and it works fine, I prefer doing this manually , not relying on a default profile.
I have my settings saved as well, only issue I have is if they are packaging this software with their products it should work. I've submitted several tickets, 5 at last count, with every BIOS update and it's still not fixed. Plain and simple you shouldn't have to "work" with something that's supposed to be one click and away you go. ;)
I submitted another ticket to MSI, if they reply with anything useful I will get that info in here. Seems like it's taking them forever to get back to me again though  :biggthumbsdown:
MSI sent me this link Link removed to an updated Control Center version 2.2.004.   Getting ready to install and will post back
ok well I guess I can't put a link to the fix up  :rolleyes: but the new control center works great now, hopefully they get the site updated with this soon
